i have heard that a cheap and effective upgrade for the RB26 440cc injectors is a set of RX7 series IV 550cc injectors that fit striaght into the fuel rail..
there is a guy selling a set of 550cc injectors that are off a 13B turbo.. but he isnt sure what series they are from? without knowing what series, would it still be safe to assume that they would be suitable for use on an RB26 or not??
i think he said they were used on a VL turbo for a while if this helps?
thanks for any info.. :D
https://www.sau.com.au/forums/topic/59598-gtr-injector-upgrade/
If they have a brown top they will be low impedence and suitable for drop in replacement.
If they have a pink/purple top they will be high impedence and will still work but you will need to remove the factory dropping resistor pack from the loom.
I cant remember part numbers off the top of my head but it really does come down to the colour of the plug as there are series 4 high imp injectors out there with low imp part numbers (i have a set) the difference is the plug colour.
cheers thanks for the info.. i think they have a brown top so looks all good, if they did happen to be high impedence tho is it a big job to remove the factory dropping resistot pack from the loom?? and after doing so would they then work exactly like low impedence injectors?? thanks agn..
they actually have purple top.... do u think its would be worth the effort to make them compatible? they are quite cheap.. or should i just save the time and effort it and look for some low impedence injectors?? is it an expensive/ inefficient process or simple??
cheers
Simple, all you are doing is chopping the wires either side of the resistor and connecting them back up.
You may need to modify the injector plug to fit the GTR plugs as the rx7 injector has an offset locating pin. All you need to do is file it flat.
Have heard people report these injectors failing in piston engines costing them there whole engine.
IMHO if your going to get injectors then get a set of SARD or Nismo or HKS or whatever bolts in. get 700cc - much better to run less then 70% inj duty with room for improvement.
I've run them for 6 months in an rb20 with no problems, it all come down to tuning. What i did notice was at idle and low revs on high vacuum i needed to add a bit of extra fuel for the car to run smoothly, otherwise no problems.
They are all single pintle top feeds after all. If we were talking rb25's it'd be a different story
The main thing is that they are cleaned and flow tested before installation.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
