Its on Friday, and I think Jayce said he needs definate numbers this afternoon to book with so make your mind up boy!!
OK i will not be able to make dinner!!! as my flight gets back in however i will probably come out and say hi to yall :D
what are you all doing after the dinner at the restraunt ???
  • Replies 73
I am so boonerfied I just bought a VL COMMY :D
............. so sad.......
I will replace the holden badge with a nissan one....
Wish I could bring the GTR out as it looks a fair bit better now, but I have not yet finished the snail instal.
Jayce Like i told you lastnight in braddon that i will be coming after work for a bit finish work around 8 so will pop in and say hello to every one and check out the tits and cars that will be wandering around the street.
if we didn't just spend 22,000 on new furniture for the new house we would come down and occupy a table, but the DIRTbank is feelin' the pinch.
DIRTbank- :bahaha: Seriously-22K on furiture?!That's,like...2/3rds of an OS Giken 3L kit(hint hint)
Alright:all done!To answer Nik's question-yep,outdoor seating.
Final numbers are as follows:
*John(JB)
*Stu
*Kyl
Richard(Sinista) + friend
Andrew(VeilsideR33)-but running a bit late...
Nik(Amaru)
Ewan(Aurora)
Gus(R31_Silo2)
Mark(the drunk)
*Fitzy
*Michael
*Terry(window tinter to the stars) and Brooke
*Jo and Michael
Stirlo
Wayne(Rumble)-welcome on board! + 1
Al(SAU Vic vice prez') + 1
Final numbers: 21
With possible guest cameo's by Leech,GTS_duy and race_snooze...
I'll endevour to get there a bit early to make sure things run smooth-official time to "move into staging and watch the lights" is 7 pm.Those of you that plan on giving the bottle(or whatever) a large nudge that night,remember to cash someone up BEFORE memory loss sets in(preferably me-as I'll be the one stuck with working out the bill...).The newbies that don't know me,just look for a black and grey Nismo pitshirt(Damn you,Andrew!Now look at what you've done!I'm already planning what to wear...Then again,is it any suprise that I'm wearing somethin Nissan?!)-righto,everyone:see you there!
Hi Allan,
Just SMS'ing mine and Jayce's number Now.
Richard:cheers:
Can someone please sms their mobile number and name to my phone, so that i can contact you, should i have trouble locating the place, etc. Thanks.
My mobile: 0427 076490
c ya there!
Alan
:D
c ya there!
Alan
:D
Sounds like Richard already has got my number to you(Thanks,R. - I'm a bit slow this morning...!).Look forward to catching you all there! My mobi' for anyone needing directions or whatever:Jayce, 0414 484 171.
For whatever 'ey Jayce? :D
Well,y'know...gotta keep ya options open! I also offer counselling,parts exchange,boy-to-girl chatline,perscriptions filled...a plethora of services,actually! :bahaha:
Hey Guys,
I am heading over, and would like to catch you guys after dinner if I can, not that I don't eat - but I'll only get to Canberra around 9. Are you guys going to be cruising around or be anywhere I can find?
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
