Can anyone tell me the hub face to hub face length of the aus-spec r31 / pintara diff housings?
If I get the chance I'll measure it.
from what ive been told the 31 and pintara are the same diff???
They use the same Borg Warner model 78 (BW78) diff housing. Pintara uses different ratio gearset (4.1), 25 spline axles and 2-pinion centre. R31 Skylines use 3.7 or 3.9 gears (manual or auto), 28 spline axles and 4 pinion centre.
and can an LSD centre be put into an originally non-LSD housing or is there a specific housing for LSD use??
All parts are interchangeable between R31 Skyline/Pintara diffs. Cars with LSD used 28 spline axles, so if you want to put a Skyline LSD into a Pintara diff you'd also need to change the axles.
BTW, VL/VN Commodes and some Fords also use the same BW78 diff
Ɨ
Ɨ
