Im a bit of a newb to the skylines i only got mine about 3 weeks ago. Anyway on friday while driving i noticed my car was loosing power, i would notice it would lose power but then i could put my foot down again and it was fine. Later that day i was driving along when my engine cut out and wouldn't start again. I disconnected one of the fuel lines and turned the ignition to pos #3 to prime the fuel pump but no fuel came out the line, cranked engine over still no fuel.
Got her towed home and i have just checked the fuel pump wiring. On the pump are 5 wires going though 2 clips i put a multi meter on them and turned ignition to pos #3
Grey Clip
Black Wire - Earthed (confirmed)
Green? Wire - 12v
Gray w/red strip - 8v
Brown Clip
Two wires can't remember the colour but both showed zero volts.
Can anyone confirm for me what each of these wires do? And with confirmed power through the grey clip can i conclude that my fuel pump has died?
Cheers for any help guys
https://www.sau.com.au/forums/topic/59611-fuel-pump-dead/
the grey clip sounds like your fuel guage sender unit.. with the grey w/red strip being the response wire which will vary with fuel lvl!
the brown clip sounds like your fuel pump wire... since the R33's use the ECU to vary the current on idle means that your pump is not gettion power from the ECU .. check that PIN 18 is properl;y connected by removeing the kick panel and unplugging then reinserting the plug ....
the fuel relay in the rear fuse panel may also be blown .. check those too and have them tested properly.. im no where near my line so i can check which one it is for you.. shouldn't be hard to diagnose this, and i doubt that it would be the pump causing this situation!
Hope this helps :cheers:
CT
https://www.sau.com.au/forums/topic/59611-fuel-pump-dead/#findComment-1137735
Ok well i went through the boot and found the fuel pump relay. It looks ok but im going to buy another one today and chuck it in. Fingers crossed that that will fix it :D
I pulled the ECU harness off in the kick panel but i'll be buggered if i can match pins to the wiring diagram that sherlock_nzl posted :D
https://www.sau.com.au/forums/topic/59611-fuel-pump-dead/#findComment-1138746
Chucked a new fuel relay in just to see if that was the problem but it didn't make a difference.
I was just going to get the relay tested but when i range up the parts place they said they have some which are classified as old stock so i could have one for $20
Bargain :D So even thou it wasn't the problem at least i have one spare now :D
Can anyone recommend anything else before i get it towed to a mechanic...
https://www.sau.com.au/forums/topic/59611-fuel-pump-dead/#findComment-1138879
Ok update, im a idiot! Spoke to my mechanic friend who told me a fact i should have known. When turning the ignition on it only supplies power to the pump for approx 3 seconds. So by the time i got to the back of the car to check the multi meter the power was off.
I checked it again and there is power getting to the pump so its definatly a faulty pump :D Time for a new pump... *sigh*
https://www.sau.com.au/forums/topic/59611-fuel-pump-dead/#findComment-1138949
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
