Hey Guys,
We've got a new member who thinks he's faster than theo:
http://www.skylinesaustralia.com/forums/me...ber.php?u=15930
9.2 seconds down the quartermile in an RX8..
Looks like he just joined.. I say we welcome this member, then follow with..
Wheres the timeslips? :wassup:
https://www.sau.com.au/forums/topic/59630-weve-got-a-winnah/
ha ha ADFA mechanic an officer in ADFA only clears $23,000 a year most of them are fresh out of school they get a loan and repay like 28% intrest on a flash car and think they can work on it at the shop most are sadly mistaken he will be on that pay bracket until he graduates to become an officer this could take 4 years. Defence love to talk it up and drive flash rides but there is usualy nothing under the bonnet flash. let him have his bottle because in time people will have to call him sir and he will be forced to grow up.
I never knew there were mechanics at ADFA. Apparently it is supercharged and turbo'd............
Anyway, a lot of young kids are like this. We soon set them straight :P
those details make no sense, inducton: twin turbo, then he says supercharger and turbo, fenatic...... F-E-N-A-T-I-C, no R, only little boys with civics use the letter R, 890hp, at barbagello, isn't that a actual race track not a drag strip ???
For starters it's spelt 'fanatic' not 'fernatic' so he's obviously got the know how, not to mention the fact that you are right in saying that Barbagello is a race track and does not have a drag strip unle you count the main straight which goes up and down, or the other straigh which has a 180 degree bend at the end of it. Obviously a nutter :bs!:
yes there are mechanics in ADFA they are either called meo's or weo's (weapon enginering officer) i forget what the first one stands for but generaly known as an enginering officer's
and i know what some of you are thinking dosen't sound to bad but working on 400 year old engines isn't fun especialy when an engine the size of your car puts out less kw than a stock gts-t
the supercharged turbo thing comes from the detroit donks they are turbo supercharged ha ha ha ha
serving his country by loging on to skylines australia during work hours ha ha ha i love it we will be paying his wage for four years while he picks his arse in a classroom then he will only do two more years acualy serving his country then leave and join the dole line with nothing to show for it except a trail of debt and pregnant women in every port.
the army didnt except you did they .. lol
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
