Crashed My Car On Boxing Day...
oh heres the story my friend was driving my car takeing me and a friend home around 12.30 and while taking a corner a bit to fast the rear end kicked out and what can i say...
we went straight onto the and over the gutter and the rear end passenger side took out a tree..luky we werent killed :blah: :blah:
(No insurance 3rd party)
now i need to find a repair place that does good jobs fixing skylines and is not going to rip me a new asshole
im located in Melbourne, VIC
can anyone reccommend me anyplaces to get my car fixed
[email protected]
https://www.sau.com.au/forums/topic/59646-crashed-my-car-on-boxing-day/
on the basis that you didn't die, AND don't have insurance
you are a dickhead
haven't seen those crashes on the news recently?
maybve u should post this in the melb section.
im assume ur the biggest **** head ever (GTS_DUY).... i do have insurance but 3 rd party and u dont even know the whole story or what the damage is
so am i asking for u for what ou think about me..NO
and yes my friend is paying for it hes a good friend of mine hes doing all the organising to get ma car fix as possible already got the money lined up to pay for repair.. but im trying to help him out buy finding the best place possible to get my car fixed. so id rather some constructive information please.
the main problem is probarly fixing the chasis theres minmal body damage but he gutterd the car and bent the rear wheel.
do you own a 33 or a 32? or a 34?
if its a 33/32, it might be more worthwhile to sell the car as a wreck, and get your mate to pay you the amount of money required for a repair or at least the difference btw the mkt value of the car less scrap value. Reason being- given the high cost of repairs here in aussie, the final amount might be more than what u initially paid for the car.
i.e cost of r32 - 12k
cost of repair - 8k
value of wreck(half cut) - 4k
might as well write it off and get ur mate to pay you. U can then go look for another car then. After all....bent chassis...even when repaired, might not be as good as new, and u'd have problem selling your car in the future cos pple dont like buying bent cars.
Guys, why are you being so harsh for?, he wasnt even the one driving. Just how fast did he take the turn? why wernt you driving?
he was taking the corner at around 40-45 km.. but as we were coming out of the long turn he hit full boost and then laters to rear end kicked out. and laters.
oh yeh it was a r33 gts-t 1994
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
