DUDE!
lol
i assume you mean flutter?
flutter is compressor reversion and isnt good.
sure you may get the attention of sidewalk sam but its really not helping anything but your ego.
yeh sorri man ok cool now i got ya!!! sorri bout the spelling but yeh so if i install a 550hp turbo will 550cc injectors be a good upgrade for this turbo?? or do i need larger injectors???
Get a PFC,Injectors from a GTR, Walbro Fuel pump and a GCG Hiflow turbo.
I have a fuel pump for sale Walbro 500bhp, replaces standard fuel pump. Self Install with instructions.
Running no BOV is fine.You can run no BOV on any turbo/engine/setup it wont make a differnce and wont do any damage. - This will give you a huge flutter noise instead of the "ricey" PSCCCHTTT.
Petar.
LOL.
Running no blow off with any semi-decent amount of boost = buy a new turbo.
Flutter that you will hear on turbo VL commos is the built up pressure (air) going back (the wrong way) through the turbo and being 'chopped' by the turbine. Might sound fully sick but really doesn't do very good for your turbo.
If you wan't to be a sick habib find a big blow off valve and attach/weld a whistle that you like to it.
Then you can have any sound you want because the venting will go through the blow off, then through the whistle.
The whistles go wWOooooowoooOO.
(and yes.. I'm not joking. If you really want to do this you can do it.)
I believe the term is "dose it" and add a few "bro", "mate", "fully", "sik", etc...
So very sad, i think i'm gonna start making and selling sound-effects kits, shove a speaker under the bonnet and you can get:
* "Turbo Induction Noise"
* "Super Blow-Off PSSSST!!!"
* "Dose" (also known as "flutter" or "flooder"/"fludder")
All at the touch of a button, wrapped in fake carbon fibre, covered in LEDs, neons and UV!
GUARANTEED TO ADD 25RWKW!!!
I reckon they'd fly out of Autobarn at a cost of $599!!!
Remove the stock BOV - get an empty can of beer and cut a gasket out of the can the shape of the BOV, but DONT cut a whole in the gasket for the air to flow through and then mount the gasket back onto the BOV. You get no blow-by to the BOV so the "flutter" you hear is the waste-gate venting itself.
This is how my car came from Japan, however I removed the can gasket for a clean, stock BOV sound.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
