This one depends on how picky the copper is.
Most cars are required these days to have a 3rd brake light.. i just over came this by installing a brake light into the skyline panel between the lights ... looks cool and has a purpose :cheers:
ANY change of the original design can be defected if it isn't engineered,including rear wing removal.Did you know you can get defected for a non-standard stereo head unit?Or non-factory fitted tyres,even if they're standard size?Or an aftermarket radiator cap?Basically,if it's changed,and non-engineered,they can do you for it.Simple as that.It's at the discretion of the person that pulled you over(Police are usually nicer to deal with than the RTA crew...)as to wheather you get a slap on the wrist or a full fisting over "the pits".I've found it depends on the modification,and your attitude at the time.I got yanked for an undersized numberplate on the way to Auto Salon Final Battle earlier in the month.The Police officer was really good about it:only cautioned me-21 days to change it back,no fine,no inspection.He looked over the car,spotted the roll-cage,rims,gauges etc.Even looked under the bonnet:the numberplate was his only issue.We wound up having a chuckle and got on with our respective days.The same officer pulled over a very well known S15 show car-and booked him for too low,and a BOV(my car has two that weren't mentioned or noted by the same Policeman...).Attitude and level of modification is important...So,removing the wing,putting in a third brake light should let you go unhassled,but engineer it if you're concerned about overall legality.
heres a few :
added the lights like i mentioned in my other post : skyline panel
add a LED set like the R34's in the boot
use an LED cluster in the rear window like most modern cars
are you going to get a different wing -- put one in there if you are
lots of other options depending on what you are about to do this car!
Yeah you're supposed to have a high mounted brake light. If you're taking off the spoiler, you can buy a light that sticks to the inside of your rear windscreen for about $20 from any autoparts store, and wire it to your brake lights.
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
    • Thanks Rezz...   👍
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
