For your infomation
there is After market ECU for Non turbo RB25DE (neo or not)
BLITZ Access computer...
cheers
Joe
oopps sorry, My R33GTS4 had one of these, I dotn know exactly where to get them, but I tell you
they improved my fuel efficiency and Power managements of the car very well.
I have lost the link of the BLITZ ACCESS site... but I am sure you guys can search one out. they are definately made from BLITZ.
cheers
Joe
step 1: hook up a SAFC or similar, i am not running on of these but i heard they are good. the standard ecu runs very lean down low at wot afr 15.4:1 on mine and works its way to about 11.1:1 at close to redline.. so gains can be made everywhere by aiming fore somewhere around the 13.5:1 mark
step 2: if you are feeling a bit shonky wind more timing into it by rotating your sensor on the front of your cam cover. i did so using a timing light. gave it an extra 5 deg. worked a charm.
  • 3 weeks later...
Got my car back from getting it's New link ECU installed and dyno tuned today.
Results were pretty much as expected, Got a gain of 7 rwkw and 21Nm of torque.
Air/ fuel ratios are at 13:1 and injectors are at 58% of there duty cycle.
Peak torque is at 4750rpm and max power is at 5500rpm.
I'm a bit concerned with the power hitting it's peak so early in it's rev range and starting drop off quite quickly by 6000rpm. Any idea's on a way that I can get it to hold it's power for a bit longer? Cams??
What about a unichip? i've heard they do good things for a turbo, what should i look for with a unichip or some sort of piggy back to get some gains..?
Can anyone speak from experience, or recommend any sorts of ecu systems that'll help??
A mate of mine had a UNICHIP on his WRX and had nothing but problems with it, recently they ditched the unichip and just went for the fullhouse MOTEC set up which has improved the car out of site. He's now going through the process of getting the car fully engineered with the MOTEC (including an emmissions test).
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
