As the topic says,
I am currently considering selling my car, however I am in no rush to sell it, so I thought I would just see if this thread would generate any GENUINE interest.
Car was bought 3 years ago when it had 80,000kms and has been garaged in the country just south of Perth for the majority of that time (read: country kms). The car now has 155,000kms.
However, in the previous 15,000kms the following has been done to the vehicle. Please note, all engine modifications are brand new....less than 5,000kms.
Interior:
Apexi EL2 Boost Gauge
Apexi EL2 Exhaust Temp Gauge
Apexi Controller Box
Apexi Power FC
Apexi Power FC Hand Controller
Momo Race Steering Wheel
Suspension:
Hotbits Fully adjustable coilovers
All bushes replaced including rear cradle bushes.
HICAS lock kit
The suspension has been thoroughly inspected and nothing needs to be done.
Engine:
JUN Super Piston Kit 87mm (Displacement close to 2.7L)
CRD modified aftermarket Conrods.
ARP rod bolts
Aftermarket Bearings
HKS Metal Gasket kit
N1 Oil Pump
New Crank and pullies
Brand new R33 GTR Water Pump (replaced a few days ago)
Tomei Sump Baffle Kit
N1 Turbos (0.64 housings)
RB25 Air Flow meters
Nismo 555cc Injectors
Head has been shaved and polished and modified for aftermarket JUN cams. These have not yet been fitted but can be fitted at buyers expense. ($1500).
Brakes:
Front rotors machined
DBA Slotted rear rotors
Ferrodo DS2500 Pads
Additional Info:
17inch 3 piece Stern Rims.
Bridgestone S03 tyres. 255/40/17. Plenty of tread.
Xtreme Ceramic Brass button clutch. 2500lb P/Plate.
Car has been dyno'd with a very conservative tune resulting in 402rwhp on Perths OVABOOST (Formaz) dyno. Genuine 11second car but has not been tested with current level of modification as yet.
Car has been maintained to a high standard. Lots of money been spent on it. Will consider swapping for a newer/late model performance car, plus cash. (Depending on car).
Car is also due to appear in a club mini feature in HOT4s in a couple of months.
42K ono
PM me if interested.
https://www.sau.com.au/forums/topic/59737-eoi-skyline-bnr32-perth/
  • 5 weeks later...
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
