Here's a heads-up to ACT SAU'ers chasing an elusive R34 GTR RB26DETT.I have it on very good authority that this engine has less than 10,000 genuine kilometers on it(in RB speak-it's only just broken in...).Those in the know will already recognise the R34 spec' engine as a superior RB series to what I have in my car and any of the R33 GTR's.If you're not up to speed,the 34 RB26DETT had different lift and duration on the factory "bumpsticks"-which is one of the reasons why 34's have more Kw and torque straight out of the box over other GTR engines.You can't retro fit these cams to earlier engines;the head had a totally different casting to make the camshafts fit.Plus the 34 block has the same strenghtening "webbing" that the fabled N1 blocks have:much better strength once you start to lean on these engines.This particular engine is a long motor:no turbos or plenum. Everything else is there,as far as I remember. The other bonus,and a reason why this particular RB is not in the normal "For Sale" section(yet...)is that it's here in Canberra right now!It's a good mate's engine,and he's not asking the world for it(believe me,if I had the funds available,you lot wouldn't be reading this now!).Whilst the engine is easily viewable,I don't need a million wannabe engine tuners wasting his time;if you're SERIOUSLY considering the best of the RB26's,drop me a PM and I'll put you onto him.The offer is there:those wise enough to know what this thing is better get scooting!!
https://www.sau.com.au/forums/topic/59862-r34-rb26dett-for-sale/
Sounds good but read the rules re. posting a price. As Prank would say, this is not an auction...:D
Cheers
Ken
You're right Ken:it's not an auction.It's first in,best dressed.I'm not the seller,I just hold his mobile number's privacy in enough regard not to splash it around to all and sundry. He really should join the forums,but I'm "it" until then...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
