Question to you - What's the product look like?
Q: Sounds great, how can I order?
A: You can order through our website either by 2 methods, using a
credit card or sending us a Western Union Money Order using
BidPay which can be purchased online as well.
Sounds dodgy :)
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140373
weather they are dodgy or not I dont really know.. unfortunately it looks that way... the biggest problem that I have with all these lambo/scissor door kits that are out now is that they dont actually lift the door up high enough. most max out at about 65 degrees and would make it awefully difficult to get in and out of the car..
unfortunately also the kits that will make the door go to a verticle 90 degrees or very close to it cost a damn site more at approx 2.5K just for the hinges. but IMO if you want scissor doors then you wanna do it properly coz if there low its just going to be a major pain in the ass...
cheers
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140379
cheers
I agree with Bassula... If your gonna do it may aswell do it properly...
Also with some of the kits available today they alow the door toswing out around 45 degrees so you can still get out normally...
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140423
Here are some examples for you to see what I mean...
This skyline at final battle with a scissor door kit fitted and the doors hardly go up enough to get in and out of the car.. it would do nothing but piss me off trying to get in and out of that.
as opposed to this which is a friends car fitted with the before mentioned expensive kit. muc muh easier to get in/out of and looks a damn site better too.. :)
cheers
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140434
Does that Calibra have any trouble opening his doors in multi level carparks?
I just thought that with Lambos being so short, they wouldn't have any trouble, but with a taller car such as a Skyline it may have trouble. But if this Calibra doesn't have any trouble, then it should be alright on a Skyline.
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140629
as far as I am aware it doesnt.... but I'm not too sure if he would actually let his car visit a multistory carpark in the beginning tho..
but you can see by the pic that they lift up a fair way but its still fairly low in comparison to say a 4wd etc... I'll see if he know the exact height of it with the doors up.
cheers
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1140806
scissor doors = Rice and only adds wank factor to the car...
I have to agree with Krzysiu. I'd feel like a wanker opening the door in a Skyline fittd with a Lambo door kit. I dont have a GTR badge on my GTS-t so I wouldn't want a Lambo door on a Nissan.
But each to their own. Good luck with it.
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1141111
I thnk it is more the fact that it makes your car unique...
I dont' think everyone wants to drive around in a R33 that is no different to his neighbours R33...
One of the good kits would look quite good..
I would go the GTF Kit as it open full 90 Degrees and also alows you to get out without lifting the door... (for yor multi level car parks...)
http://www.torquecars.co.uk/styling/gullwing-doors.php
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1141284
I could get you the hinges..... as to finding some1 who can fit them I'm sorry I wouldnt know... a decent panel beater "should" be able to do it if they are willing to do a bit of custom work.... I have seen the GTF kits in the flesh and fitted to a car and I dont think they are overly hard to fit... would just have to take some time and patience to fit them...
if you are serious about it drop me a pm or something and I'll see if I can find you some more info...
cheers
https://www.sau.com.au/forums/topic/59895-gull-wing-doors/#findComment-1141465
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
    • ECUMaster is an Australian company from memory, been around a while, and seem to actually play really well on more unique engine setups. Seems to be more of them being used in the states, and they seem to support more cylinders than most others.   My opinion on stock ECU/Nistune with he AFM, is you can tune around the issue of stalling. It's still a bit of a band-aid, and not the most perfect smoothest setup, but it can make it drive able and not an absolute PITA. But you're still compromising. A vent to atmosphere BOV has the same issue as no BOV with regards to the AFM. Both make the ECU think more air is entering the engine than there really is. And I can't find any hard science/decent evidence that supports the claims all the "you MUST run a BOV of some sort of you'll blow the turbo up". About the only one some people can give of why is "lag between gear shifts", and that is only an issue when your boost source for the waste gate is pre throttle body. I ran my boost source for the TD07S off the inlet manifold. Didn't have weird boost spiking issues, didn't have boost control issues, and on a gear shift the wastegate slammed shut, which meant all exhaust gases would be keeping it going round and round and not waiting for the wastegate to shut again when I stepped off the clutch and back on the loud pedal. It came back on boost in the next gear pretty much instantly.   ECU / tune / BOV choice I think really comes down to a lot more factors than just what you've stated. And personally, especially for daily driving, recirc setup for the BOV, or no BOV. I dislike the really loud BOV when everyone is taking off from the lights etc.
