Hello everyone i got me a r33 1995 gts-25t stock off its nut.
Now i want to put a Blow off valve so i can be fully sick haha.
What i need to know is everything one needs to know about and how to installa Blow off valve ...
IE
what type of BOV is better - what are the different types?
How much does it cost to install and how much shud i pay for a BOV?
REMBERING my r33 gts-25t is stock as a rock - so i dont need any high end gear.
Also when installing a BOV do i need to have my onboard computer tweaked? (not aftermarket the stock one)
Thanks Guys - All info is greatly appreciated
Cheers
https://www.sau.com.au/forums/topic/59908-hello-_-bov-questoins-for-n00bie/
OK were to start... :kick:
if you just want to be fully sick like you said, just put a pod fillter on and u will have the same effect, the stock valve makes enought noise to be noticed.
If you want to go aftermarket BOV u will:
(Aspeacialy with a cheap bov)
1. back fire
2. Your car will sometimes stall wen coming to a compleate stop eg- trafic light
3 loss of fuel economy
( Please correct me if im wrong )
( they are just some of the things that had happen to me and other people on these forums )
For them things to stop u will need an after market ecu eg, PFC or e manage ect the original computer can not be tuned.
Alot of people do chose to stay with the stock valve as it doesnt leake untill about 17PSI but then again wen the small hole on the original valve is blocked it doesnt leak at all.
Please sell your car to someone who deserves it.
BOV on stock car just for the sound = loser.
Use the money for more useful things - "PERFORMANCE PARTS" perhaps.
The only reason I'd get an aftermarket BOV is if the stock one was leaking (thus loosing boost). Reasons for this have been stated above, but most importantly the fine you get when defected for it is not worth it, expecially if all you want it for is to make some noise.
If you still want one, try a Stealth FX from GFB. They have a model built specifically for R33's and bolts on in a matter of minutes. I'm sure that Turbosmart also make adaptor kits for R33's as well for all their BOV's.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
