I have for sale my R32 GTS T
Bought in 2001 with 68K on the clock and has been in storage for the last 8 months. Current KM is 84K
Have just replaced all pads and rear tyres , front tyres are 30%. Also just replaced the PS pump ( HICAS ) type
Current VIC reg with 4 months left ...
Vehicle is UN modified and I am asking $13,000.00
If you are interested then call 0402 458093
have tried to attach piccies but problems .....email me for set [email protected]
Wes
https://www.sau.com.au/forums/topic/59914-1993-r32-gts-t-5-speed/
blue dials,
clear front indicators
rb20 timing belt cover ?
all signs of a pre 1990 skyline
exactly. Also the seats and the interior centre console cover.
Just trying to provide more accurate information for potential buyers.
Hi Guys .....
have taken your comments on board.
Are you saying that this vehicle is pr 1990 ????? If so then I have a vehicle that is not what it appears to be ......
Where exactly do I check the VIN No ????
low volume compliance was done thru GE-TE-R Motorsport in June 2000
I am also confused re you indication on timing cover .....I believed that all R32 GTS T's had the RB20 motor , is this incorrect as well ????
Front indicators I have replaced the r/h and was not aware that there is a diifference ...l/h indicator has been sprayed over with a dark black tint so who knows where this one came from ....
This is my first skyline and I love it , however I am not an expert on speed dial faces or other stuff that you seem to indicate are wrong with this vehicle .....
If you guys think this vehicle is not genuine or not what it appears to be then I invite you to inspect thie vehicle and put the record straight ......I am not out to deceive anyone.....
I can only rely on the purchase checks done by the dealer and VIc Roads as to the credentials of this vehicle when I purchased it in 1991
Wes
yeah, the newer rb20's dont actually say "RB20" on the timing cover.
good luck with sale
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
