  • 8 months later...
its one of the guys from NZ.
its not matt black either its satin black... there is actually a big difference.
very fat car... even has the rims im buying for my 4door.
as ive said in other threads... the std 4door lights look hot on dark coloured cars... just not white or silver.
i always thought it was such a shame that they never made those any bigger than 17s... but all the skylines and other cars ive seen em on look bigger than 17s anyway.
still... 18s would look fat... but only Bee-R make that exact style in 18s and they look fat as.
yes it can be done but its a hell of a job
you will not need to change the rear guards but you will need the corners for the tail lights on the boot from a coupe
you will need to cut out the area behind the tail lights to make the coupe ones fit
rear bar lines up ok will need to have to change the reinforcement to a coupe one
and you will also need the reverse lights from a coupe
thanks to UPI for lending all the parts to test fit
pics attached to those keen to try it and want ideas
Its a huge custom job. The 2 door tail lights are nearly 2 inches taller - as is the bootlid nearly 2 inches wider. The curvature on the outside of the housing is also totally wrong for the sedan.
I dont think you'd be able to get a real factory looking job without some serious custom work.
I've decided to deal with the sedan lights and find other things to worry about.
Jash
  • 6 months later...
Hey gaffa, can you please answer the above question.
I'm interested in this conversion as well as I had a slight stuff up with my rear end and finding it hard to source 4 door parts. Also I don't mind the look of a 2 door rear end and if possible I would use the 2 door parts.
Thanx
Ned
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
