hi guys,
im changing my timing belt, and i need to remove the main pulley. ive pulled of all the belts and also undone the big bolt in the middle of the pulley, but the pulley wont budge. is there any other things holding it in?
Also, my diff is locked and i wanna unlock it.
does anyone have a tutorial with pics on removing it?? also, would it be possible to unlock it?
thanx
steve
G'day Steve,
You'll need a gear puller to get the front pulley off. No other way around it :)
If I remember right, it's tight for space down there, so you'll probably have to get the radiator out to get the gear puller in there to get the pulley off.
Locked diff.... So is it a 1/2 way diff and you want to make it into a normal LSD ? If so, you need to replace the diff centre. Some mechanicals are adjustable (to a point) but not all.
J
thanx for the info jay.
the radiator and everything has been pulled out so fitting a gear puller isnt a problem.
i was hoping there was a pin or something i could pull on the diff etc to unlock it.
Does any one have any recoomendations on a suitable diff for an r32 gtr?
Theres a perth guy selling a 2 way for $500. would be ok??
thanks heaps
steve
