my 33 gts-t is the same, if your givin it some stick in 3rd and go for 4th like over 5000 rpm u get some crunchyness - still gets into gear fine just the noise, all other gears are fine
i think a saw some other threads on this that were talking about fast syncro wear and the box being naturally notchy ?
time to change the synchro's in the gearbox.......if you keep going you will also need to replace the gear as well......thats if its not rooted already.....people....put the genuine oil in them and save your selves heart ache.....
I still buy them thru Nissan and 4th synchro is very common on GTRs and GTSs.
Give me the name of your parts guy and a contact number, I'll get my parts guy to talk direct to him. I've been through all this with Nissan (local parts, central parts distribution and all the way back to Japan) and my own investigation using FAST software has confirmed. The original type R32 GTR 4th (and 3rd) gear synchro has been superseded BUT the new part does not fit without replacing a bunch of other associated parts (eg engagement ring, hub, input gear, etc)
Funny but my seem to be THE OTHER WAY AROUND, at high RPM, no problems but like under 4000rpm it crunch very easy :headspin: .
I agree with ylwgtr2, it's probably time for a synchro refresh. But I would try an oil change first, we use Castrol Syntrax 75W-90
Will definately give that a go first, worse come to worses how much would the whole job cost for syncros replacements? How much is a good condition R32GTR box and labour?
Thanks
the way to Fix the infamous earlier gearbox problem is to convert it into a double cone synchro...this requires a bit of machining but fixes the problem for good....i will have a hunt around and see if i can find my pics on machining them
here people.....this fixes it....1st pic is what the untouched gear looks like......2nd pic in the lathe and machine the single cone off......3rd pic mill 4 slots in it for the double cone synchro boss hub to latch onto the gear....
and you get the double synchro hubs and sh1t from this guy 0453510421.....its a japan number so you will need someone that speaks japanese to order the parts.......you could mod it to use a getrag 6 speed double cone assembly....but thats uncharted waters for me....but if i have to do another one....id be sizing it up that way as i now have plenty of getrag V160/161 parts here now
To be clear, those pics aren't of 4th gear, but of the 1st mainshaft gear - I can make out the sub-gear used on the 1st MS gear in one of the photos. The 4th gear synchro is also of the single cone type, but is actually part of the main input gear (ie the shaft that sticks out of the front of the gearbox and is what the clutch plate is attached to).
yes but the same mod is done to 4th aswell.......the part your saying is part of the gear is the dogs that the synchro ring mates the shift drum too....these dogs are prone to shearing off if the synchro ring is eitheir rooted,the incorrect oil is used or continued abuse of the transmission
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
