  • Replies 66
I would have come if i had checked the forum earlier. I hope alot of money was raised, they sure need it. Makes me feel bad i have a roof over my head and nice things, while they have apsolutly nothing. Wish there was more i could do. Makes us feel lucky about our families that are around us and what we have, and that we never know what will happen tomorrow.
well from the first and 2nd meet point it was HUGE guys...
well done to everyone who showed up and donated some money.
apparently there was cop trouble at the start, dunno bout the rest of the cruise though
good work to everyone who took part, sorry i didnt hang around (although half u wouldnt have noticed anyways ahaha) but i was buggered from the weekend and hungry.
What a fantastic turnout! Jeeeeeeeesus, good on you WA for getting behind such a worthy cause. Will be good to hear the final count on the money raised. I took off after the Bunnings checkpoint as waiting 45mins to get into or out of a carpark wasn't my idea of a fun cruise. I did my part and donated, chatted to a few familiar faces then promply took off.
Well done to the organisers and cheers for all involved. :)
For a slow, charity cruise i saw some very stupid driving... A speed camera, a couple of accidents and some police to make sure things were going to plan made it a reasonable cruise. Hopefully the camera on the freeway didnt claim too many..
A few stupid people around which is to be expected with a cruise this size, i guess. Hopefully everyone raised a decent amount of money for those less fortunate.
did the cruise happen to go on the freeway... near leech highway exit?
i was going to the girlfriends place, and this nice R33 with a SAU sticker goes past me (SWEET 33T i think...)...huge rear wing you got!
yes it did and yes that was us, [veilside wing]. huge cruise and a great turnout with donations that will help people a lot worse off than we can imagine.
Great cruise for a great cause! Sooooo many cars. I left after Bunnings - a few people being idiots with that many cars worried me a bit! Pity about the accident, at least it wasnt serious. BUUUT majority of people followed the rules.
Excellent job done by the organisers. Glad to hear alot of money was made! :)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
