2 in and 4 out.
It flies now, it seems to have got rid of my flat spot around 5000rpm which is where the AFM was maxing out. Im very happy at the moment, stay tuned for some dyno numbers but going by feel, i can certainly feel the difference.
Once installed it ran lean as buggery, so i quickly added some fuel everywhere into it via the SAFC. So at the moment its had a quick road tune but its feeling very quick. I will have it on the dyno next week to accurately tune the A/F ratios.
Ok cool, i mite take it with me to the dyno and swap it over so it gets tuned straight away.
The Z32 is larger in size to the standard one too isnt it? That means new pod filter aswell :cheers:
So 2in4out doesn't change the afm's voltage to what the stock item would have been?
Even though you did this it still needed more fuel to be put in?
How did you know it was running lean?
2in tells me is that the safc is receiving (voltage vs airflow) from (2) a Z32 AFM.
4out tells me that the safc is changing (voltage vs airflow) from (2) a Z32 AFM to (4) a RB20/25 AFM.
So theoretically if you select 2in4out you shouldn't have to change any fuel settings as it would be as if it is still running the RB afm (5v limit would still be at the same vs airflow).
I'm about to do this to a S15 (Z32 AFM).. The reason for all the questions. :rofl:
Its called pinging. Ive added some more fuel in and its not pinging any more. A dyno test should give me the correct answers.
Yeh thats what i was thinking
so its the same physcial size as the rb25 afm? sweet :headspin:
Maybe as the standard AFM was maxing out, it wasn't getting the optimum tune at those rpms. Now with the AFM reading, the computer is giving me a decent tune, hence why the 5000rpm flat spot has gone. Im running a HKS 2530 and im seeing some strong results, though i reckon you would gain some benefits with the stock turbo.
The Rb30DET in mine takes until around 13.5:1 before it starts pinging.
Even then at high rpm the knock sensor doesn't pick up pinging, only during lower/mid rev's.
A definate ping can be heard once is hits 14:1, then it fuel cuts.
What I'm getting at is pinging is the last thing you notice when it is leaning out.
Robo, You still didn't really answer my question.
So the AFM reading on the SAFC is definately reading lower with the 2in4out?
Before it may have been hitting say 100% at 5500rpm not it is maybe 80%?!?!?
Just about to go for a test drive, i will let you know about the 100% flow.
Sometimes my SAFC changes to pressure and it takes some fiddling to get it too show Air Flow %.
I really am interested if the safc changes the voltage back to std as it may be quite a bit of a pain in the arse if I fit it to the s15 then find out i can't drive it.
Especially considering the s15 has a 45mm little hole for the afm. :rofl:
It may throw it out quite a lot more.. BUT if the safc does the adjustment and returns the voltage back to normal then it may be ok.
The settings for a S15 is In 05 and out 05. When connecting a Z32 too it, the settings will be IN 02 and out 05.
Car is running very strong. Im running around 17psi with the HKS 2530, SAFC2 and Z32. I have seen a little more on cold nights.
My dyno man is currently getting his dyno recalibrated so hopefully this week i will be able to fine tune the mixtures and maybe see how much boost it can handle.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
