  • Replies 218
depends on your setup mate. please do some research and get back to me. most run 044s in-line with a surge etc so yes, it will cost you more to install. Is the best pump made by Bosch however, and at the current price is quite a good pickup! as i said, it really just depends on what you aim to achieve. let me know.
So what would you recommend for a GTR?? Bolt a 044 in tank?
Got any available right now?
ditto.
i'm running 1bar with Power FC upgrade in the near future. Would 044 be a better option?
cheers
rick i have a DIY for a 984 which apart from a check valve the install is the same as an 044, driftkng has the link at the start of this post or it is in the list of member tutorials. rubber mounting helps dampen the noise, instructions are in the DIY or attached later.
ok wat would be the best pump for me to buy an 040 or 044 i have high flowed turbo (rb20det) 3.5inch exhaust, intercooler, stock injectors, 14psi i want to mount it intank...do the 044's come with the sock??
mate, please do the research and get back to me. none of these pumps come with the fuel sock... as mentioned pump will only flow capability of ur injectors + standard computer to start with...if you just want a replacement pump, an 040 will do you fine... but if you upgrade later and want more power this pump will become limited.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
