Guest RedLineGTR
From what I have seen there is no M Spec there is a Type M and a Type S...the exact differences well....stil not 100% sure on all of them..one is the different front bars etc.
it also has bigger brakes, and i think it's got digital climate control,and it has an adjustable front spoiler. there have been a few threads on this, but no-one has a definant answer.
hard to tell, coz a lot of the stuff that was standard on the type m you could get as an option on the non-type-m
Nissan Skyline GT-R V-spec II R34
The GT-R V Spec II has the ATESSA E-TS PRO four-wheel drive system which integrates with the LSD, giving the computer control of side-to-side torque distribution as well as front to rear. This offers improved traction. Underneath the V Spec II, Nissan have fitted front and rear diffusers which work together to smooth airflow under the car, reducing lift and creating down-force. The rear diffuser is made of carbon-fibre and features a NACA duct to direct cooling air to the rear differential. The V Spec II also has a different 2-step tachometer which has finer graduations above 3,000rpm for more accurate readings.
Nissan Skyline GT-R V-spec II N1 R34
The GT-R V Spec II N1 is designed to be the basis of racing GT-Rs. It features different turbo chargers using metal rotors instead of ceramic, an engine oil cooler and larger diameter rear brakes. To save weight some items are removed including the rear wiper, rear fog lamps, the remote control entry system, air conditioning and the audio system (although the antenna and wiring harness remain). The centre console lid and parking brake lever are now trimmed in plastic rather than leather and the external mirrors are painted black. The N1 is only available in white with an unpainted lightweight carbon-fibre bonnet.
Nissan Skyline GT-R M-spec R34
Released in 2001, the M Spec is similar in specification to the V Spec II but with a few differences. These are mainly inside the cabin where the M Spec has a leather covered steering wheel and gear knob with gold stitching and heated leather seats. Other changes include an aluminium bonnet and revised suspension tuning. Like the V Spec II, the M Spec has the ATTESA E-TS PRO four wheel drive system, underbody aero package and a 2-step tachometer.
There was also R33 GTS Type G and Type X.
The Type G and Type X R33 had an RB20E Motor.
The Type S has an RB25E Motor.
The differences from a standard R33 GTS25t to a R33 GTS25t Type M were the Front bar and Side Skirts. There was no MSpec, MSpec was in the R34 Skyline model. :P
I'm sure I read somewhere on here that all GTS25t's were type M. The type M just denoted it was a turbo car. If you do a search, you'll find a lot of debate on whether there was a type-M and what extra features you got. All I know is mine has digital climate control, the lower front bar and viscous LSD.
Type M is a "Sports package" its basically just a car with a whole bunch of options as standard. Like "Sportivo" for Corolla.
GTSes got Type S
GTSt's got Type M
GTE's and sedans got Type G, J and X
The options given as standard varied from financial year to year, as seen in the catalogues. The few options that were offered thruout the run were Sports bodykits, sports spoilers, upgraded interior trim, Viscous LSD (or Active LSD), HICAS, and sports suspension.
Keep in mind there are regular factory cars which can have these options added to them which make them similar spec. Also you can add MORE options to the Type M package, like cup holders, sunroof, EL lightup panels, gold badges, glovebox refrigerators etc.
M-Spec however is totally different, there's an LM Spec as well in R33's, the commemoratory LeMans blue editions.
Funky, you seem to know alot about the extras you could get. Would you happen to know what the black box thing on the back shelf labeled "Puretron" is? Guesses so far are a de-ionizer or an air purefier of some kind.... thats my "warp engine" mentioned above... no one else i've spoken to has one.
When I first got my car, it had a rotating inlay on the indicator stalk, similar to the intermittent wiper 'rotating bit' on the wiper stalk. The one I'm refering to was like the indicator stalk was wearing a ring with 2 positions. I assume it was a Fog-light switch but I'm not too sure because it came with a non-standard bar and I have since replaced the whole stalk assembly (it just started to click and short out one day) to another set that was identical but without the fog-light thingy.
When I looked at another mates r33 gts-t he had the standard bar with the foggies, but when I looked closer I noticed that there was only a reflector behind the glass, and no bulbs. He didnt have the fog-light ring thing on his stalk :P
  • 1 month later...
Hmm basically, all GTSt's and GTS25t's are Type-M, all GTS, GTS25 etc are Type-S.
Type-M denotes that the car is a turbo, Type-S that it is a non-turbo. Other extras may come with the Type-M (not sure) but I know for a fact that non-turbos are Type-S and turbos are Type-M.
Possibly the 'M' stands for 'Massive insurance' and the 'S' stands for 'Secondrate', not sure :D
 Share
    • Gosh these bmw's are worse money pits than JDM's! I won't complain about my car anymore 😂
    • I'll just leave this quick tip here after reading your joys of getting the car in the air. It should take no more then 10 minutes to get the car safely up on stands.  So for the front, jack on the tow recovery points (marked in red). Put the jack stands under the lower control arm mounting point (marked in yellow). This photo is of a R34 GTR, however the process is the same. For the rear, jack under the diff (marked in red). Put the jack stands under the rear subframe or where the lower control arm mounting point (marked in yellow). Which point you use will depend on your stand, pick a nice stable point.  You've probably already read this but it's worth repeating. When jacking up the car or using stands, stay away from the chassis rails/pinch welds. Even the factory jack point, stay away from that too unless using a factory jack. I used those jack points for years without issue until I turned into an old man and bought a QuickJack lol.
    • And this is where the leak is happening: https://www.dropbox.com/scl/fi/7h1vlmg2j5aa7rksvsjc9/IMG_9982.jpeg?rlkey=d3bnpau5f615zmxqmca0llvr7&st=kquvdxvs&dl=0   Apologies but it seems adding an image from a link does not work when the images are in Dropbox.
    • Here are some pics from the auction: https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0   https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0
    • Hi all, From the western suburbs here. Just got my 2000 R34 GTT registered today! Got it imported from Japan through a mate who is doing them and managed to find a decent one. This one has only done 110,000 Km and had no body rust etc. so was very happy. I used to own a 25Gt back in 2015 (ate Ramen noodles for years to save up for it), but unfortunately, it got stolen TEN DAYS after I bought it!! Came back from Uni and the car was missing - cops found it in Springvale a month later with a lot of needles  😒 It was too late by then and I had moved on to a different car (300ZX), and after that one got broken into around 2018, I was in a very bad place and decided I would never buy a car again because it was just pointless!!! ~yeah, I have some very bad mojo~ 🥺 But now, with a stable job and a secure garage, I thought I'd get the R34 4D again but not as a daily! I love the R34s but a GTR is still a bit off my pay grade so settled for the GTT instead.    The first step for me is to get this car serviced and have all fluids, belts and spark plugs changed. I might do the brakes at one point too but atm they are fine, the fluids are what I want changed since this car probably sat in a garage for a long time. I'll then get some coilovers since the suspension needs to be changed anyway (the dust cover kit is disintegrating). I'll also upgrade my car alarm to a Viper system and then look at rims and tyres (I'm a sucker for TE37s - might have enough saved in another 3 years for that).   Today: I was planning to do the oil, coolant, air filter and fuel filter change this week. Started on the oil change today and MY GOD what a pain!! I used to think the 300ZX engine bay was cramped - oh I was so wrong! 😂 I've done the usual services on my cars before so it was not like I was going in blind. I looked up all the forum details about what oils to use, what coolant to use, what points to use to jack the car or place stands etc but I did not expect it to be this hard. Long story short - all I managed to do was the oil and filter change. I think I might end up taking it to a mechanic for a coolant change because my SCA stands and trolley jack just can't get far enough underneath to the cross-member and I don't want to be crushed under my favourite car....yet. Side note: In Dandenong, there used to be a shop that lets you hire their hoists - does anyone know if they have those around? I can't seem to find the Dandenong place anymore. I contacted them off FB almost 6 years ago and I'm not in it now. If anyone know of one, that would save me some time going to a mechanic for the basic services. Oil: Dark and gooey but no metal pieces. Oil Filter: Was a b***h to take off but no red flags Air filter: Yucky! Was black (Smells like fuel which makes me think it may have been running rich? - am I way off?)   Concerns: I have but one concern atm and that is that there was a very small amount of oil leaking where the engine and the transmission connect (Automatic). It may be the rear seal? It's not a massive leak and it does not affect the oil pressures or leak oil all along the driveway. It's been falling into the cover this whole time. I've taken the cover off so I can check the garage floor from time to time.  I also have not seen my engine temperature gauge ever sit at cold and slowly move up to the right spot, but that might be because every time I saw the car today, it was running. I'll check that again tomorrow. ATM it just sits right in the middle. I may just be paranoid but I don't want an overheating engine while my gauges say everything is fine. 🙈 Other than that, I'm very happy with the car! Feels like it's about time I went back to spending my weekends driving or cutting my arm on stupid sh*t in the engine bay.   PS: I will post a pic later on because I underestimated soooo badly today and it was dark by the time I finished! PPS: I broke the two damn plastic pins that hold the intake funnel section to the front bar. This is the piece made to bring cold air to the airbox. The connection to the airbox is fone, but the two clips just broke off! Should I be worried? Anyone else done that?
