Pop. Pop, Pop...
Guest EVL-R33
Hi everyone, got my line about 6 months ago and pretty happy with it,
its a 93 Gts-t with a Trust jasma zorst looks like 3 1/2 full exhaust system with hi-flow cat and a k&n air pod,
The problem im getting is the pop pop pop at around 4,000 and upwards, ive been reading the other threads and lots of ppl have been sayin about the plugs needing remapping but my mate reckons its got to do with overboosting coz my zorst and filter is causing the turbo to get more boost and overboost,
just wana get other ppls ideas and thoughts to get rid of this problem will a fuel-cut defender help???:(
https://www.sau.com.au/forums/topic/6005-pop-pop-pop/
Take out your plugs, but before you do that go and buy a spark plug feeler guage. (only about $10)
Then pull out the slides so it adds up to .8. Put the slide in between the gap of the plug, then bend the top of the plug so it sits flush with the slides.
I bet you have no idea what I am talking about cause its pretty hard to describe.
https://www.sau.com.au/forums/topic/6005-pop-pop-pop/#findComment-90776
ok, first thing is to remove the pipe that goes over the engine..
u have to take out 2 bolts and losen a few clamps and remove some hoses, also remove the hose that goes over the engine at the front
then unplug your amplifier (black box that sits at the back of engine)
then using allum key remove bolts from black cover (bout 4 on each side).. this will then left off exposing your coil packs.
These are bolten on in 3, easiest is just to get a 12mm socket and remove all the bolts at once... then pull up on the black boxes (coil packs), they have a bit of suction so u need a bit of force, but be gentle at the same time cos I hear they break easy.
Now its as easyt as removing your plugs, and re gapping them. You would need a spark plug remover that is quite tall as they are sunk in fairly deep. Auto barn will have a re gapper thing and spark plug remover.. then re gap to .8
Put it back together making sure all hoses are tight etc. Should be fine. If your still missing, the plugs may need replacing or you could have faulty coil packs..
hope that helped.
https://www.sau.com.au/forums/topic/6005-pop-pop-pop/#findComment-90832
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
