whats wrong with silver? ive always thought it to be one of the best allround colours for cars. looks sex with white wheels too.
if i ever get a respray i would think long and hard about doing silver with a ice blue pearl, or the yellowey-green colour that alot of car makers are using now. (my mums falcon is this colour).
i agree that its good to be different and not copy, but dont want to be too flashy.
out of the three colours, the gtr purple would look good, but be a bastard to keep clean.
  • Replies 45
My last R32 was silver and I loved it.... However, I would like to move on to a colour that is a little more rare, and will make the car stand out when it comes time to sell..
I really love the puple so I thinki it is what I am going to go for.... Might also look into painting the car black, and putting a purple pearl into the paint...
Yeah i have more pics of that Exact car......
Plus the colour is actually a stock colour, limited BUT stock
Ok... Here is todays challenge!
Find out what colour code that paint is.. Would Nissan be able to tell me?
Can you please email me the pics of that car MADGT4?
[email protected]
From another thread:
The R33 GT-R Midnight Purple has been done quite a few times before, it still looks good, but I suppose something a bit more unique like II or III would be good.
Midnight Purple - #LP2
Midnight Purple II - #LV4
Midnight Purple III - don't know :(
Heres the PDF file: http://dupont.co.jp/dupont-refinish/color/.../nissan/lv4.pdf
I don't really know what I'm translating, but if you know paint code recipies then stuff like "binder", "balancer" and "flop controller" might make sense to you...
1st Part (Colour base):
*from top to bottom on the extreme left*
Skyline
Black H.S.
Binder
2nd Part (Pearl Base):
*top to bottom on the extreme left*
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
3rd Part (Colour Base):
Skyline
Black H.S.
Binder
Balancer
4th Part (Pearl Base):
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
Note: At the top of the 3rd column across from the left on each of the parts it says "1L Combination Amount".
Now if you can make heads or tails of that that'd be great, because I'd hate to think that I've wasted my time.
ive painted my R32 kandy red its very nice but very hard to paint and very expensive compared to the colours you have posted.
midnight purple I, II or III would look nice as well as cherry black and they arent very common.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
