Generally if you're getting noise through while nothing is playing, the amp is just shitty.
I remember my friend had some "no name" amp for his rears, kept giving hissing noise at low volume.. was crap, even when he moved it across into his new car, same problem. Wasn't so bad at high volume, but at low volume the nosie was annoying. My Sony amp never has any such troubles, it just has screwed my speakers over time due to excessive volumes :) It just depends on the quality of the amp.
Other possible problem could be interference. If you're RCA's are running past some 12v line then you're going to get noise.. try isolating your cables outside the normal trim (if you have everything apart) and see whether that is the problem. Old cables could also start picking up more noise if they have a nick in the insulating plastic or something similar.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
