Hi guys,
This is my first post on these forums :wassup:
I figured I'd use this post to say hi and to ask a small question.
About two days I bought my first Skyline. It's a '96, Silver, Manual RB25DET. Absolutely imac condition too. My question though, is: Do these have ABS? It has basically every other conceivable feature so if it doesn't it's no biggy.
By the way, what RWKW to these things achieve in stock condition (the only mods on this one being a SS HKS exhaust tip or something - bit loud, but sounds great above 3500-4000RPM).
Regards,
RE
https://www.sau.com.au/forums/topic/60079-gts-t-and-abs/
does your dash have an abs light? look in ur engine bay, on the upper passengers side corner there should be a big silver box thingy with a bunch of tubes running from it (you cant miss it). ...thats the abs unit. if u cant see it then u dont have abs. i dont know the exact kw, 140 maybe?? oh and exhaust tip no matter what brand wont do jack..LOL u need a complete 3" turbo back system to gain performance.
have fun driving your line:D:D
https://www.sau.com.au/forums/topic/60079-gts-t-and-abs/#findComment-1143013
    • E10, by very definition, has 10% E in it.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
