Hey ya'll.
Ok heres how it is. I got a R33 GTST 93 model with a hybrid FMIC, 3.5" turbo back with screamer pipe and HKS Super Dragger muffler, turbo smart duel stage boost controller, HKS pod filter, NGK Irridium plugs, umm i think thats about it.
Anyway me and my mate have been playing around with my duel stage and we set the low stage on about 8-9psi and the 2nd stage at 15psi but second stage when hit makes a higher whistle sound but doesnt reach over 10psi and spikes so it goes to different levels. Just wondering if there is a stock boost cut or what could be the problem there?
Also is there a rev limiter at 7? because that just seems a bit low when it still seems to be powering along and my silvia i used to have cut out at 8 grand??
My car some times when you give it a flogging (especially at 2nd stage) sometimes seems to start to choke, Its as if it cuts out fuel or something i dont know? I was thinking i might have bad fuel (we dont have optimax here any more) so i chucked some Nulon pro strength octain boost through and it kind of solved it but the thing is it doesnt do it all of the time. I duno its confusing to me :rofl:
Lastly i want to be quicker, What would be the best options for me.
I was thinking of saveing up for a e-manage, and larger turbo (but dont want any more lag then i have already on stock).
What other alternatives do i have without braking the bank. I was thinking of getting another 2k out on my loan or just doing stuff over time.
Oh wait one more thing :wassup: I want some new lowered struts and springs with good handeling but not to rough. The silvia i used to own had koni adjustables i put in with lowered king springs, handeled really well but was just way to rough. I want something with a softer ride, good handeling, and a nice lowered height, Was thinking adjustables as well and once again not to much. Hopefully less then $1500.
Be great if people could help me out with my delemers haha
Cheers :D
What condition is the rubber boot in between the air filter nand the turbo? this could be sucking closed and causing some of the problems you mentioned. You are also likley to hit the factory boost limit unless you make changes to your ECU.
PS - yes there is a factory rev limiter
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
