14.11 @ 102mph. So all the naysayers out there can relax for a bit, I still havent cracked the 13.7 on my current power level, but I'm sure I'll get damn close. Again only 4 runs, some guy decided he didnt like his lane and went for a closer look in the other lane and then the concrete barrier, he's ok... dunno about his car. For the naysayers, I'm sure you will *enjoy* daves (aka. rev210) post... ready to eat that shit that was so called coming from me about running 13's without anything more than a bit of boost?
*snicker*
Rob
https://www.sau.com.au/forums/topic/6021-its-not-quite-a-137-but/
  • Replies 58
dude get off your high horse.
great that you got a PB time.
there are alot of 'lines around with similar mods that run completely different times.
yes the power level helps, but so does the clutch, suspension etc and most of all the driver knowing there car!!!!
But almost everyone told me I needed more HP, from a SAFC or an new ecu, or a bigger turbo and front mount. I distinctly remember adam32 saying that I would need a SAFC. All I've changed is the clutch and tyres. So it goes to show that as dave (rev210) said you CAN run a 13.8 in a r33 with minimal mods. He's spent a lot less than me and he ran a quicker time.
Rob
you said in that other thread: with the current mods
a clutch added REDICULOUS amounts of power to the ground when I put mine in, and as far as I'm concerned is a modification..?? or am I wrong??
well done on your 14.11, but 13.7 is a long way from there
Rob's cars got more potential than mine ,now If I stole his boost controller,his clutch and his tyres oops...did I just say that inner monologue out loud?
Well, his car will do a 13.6 with a nice amount of wheel spin still off the line, as is the norm for the plex I now gather. He was running to much air pressure in his tyres. I dropped mine to 20psi for the 13.8. Did 14.3's with 34psi in them. If I had my best 60ft of 2.1 on that run it would have been a 13.7/13.6 , not an unreasonable assumption.
I think its good to encourage people to get their car going as quick as they can with each level of mod they make before moving to more power as a solution because the reduction in times per $$ spend is better. It's just as good as organising a discount for forum members on performance parts cause ultimately the goal is to go faster for less $$ spent.
I think if we put our heads together we can work out a good starter formula for making a stock skyline faster just like many other car types have a similar step by step process.
dude, dropping the tyre pressure to a certain pressure will of course give you better traction, but a reduction of 0.7...ummm...
we aren't bagging him or shutting him down, it's just that he seems to think that the car has more potential than it does
a change of clutch is a modification, and in my opinion a VERY good one
boosting is a modification as are all of the other ones, including free horsepower mods, they are all mods
he said with current mods bla bla
noone is putting him down because its great that his car, as with all skylines/imports, can do good times and is bettering PB's
it's just that some people seem to have some kind of competition against others to prove some lame point
I know what you mean.
I think Rob was hoping to prove the ordinary R33 skyline power plant doesn't need much to get 13's. At least he is 'trying' to prove that if you have the power he's got in your R33 sorting out the launch will get a 13.7.
This is good news to those hoping to do that sort of time without forking out big cash for front mounts and S-afcs, bigger turbos, blow off valves and HKS stickers. When someone does a 13 without these things they have something to offer their fellow new R33 owners by way of advise.
Agree to disagree about tyre pressure tho. I got a reduction of 0.6 and with less tyre pressure , my tyres are much narrower than his and are of a crapper compound. That was with less boost too (8psi). 0.7 drop even more is there for many people who are not yet in the know.
Rob
i can't remember do u have a dump pipe? fair good wack of hp there.
the new clutch would of helped greatly allowing you get that power to the ground so you started accellerating more than spinning wheels.
Rev has the dump pipe on you and his is heat rapped which helps the air flow in the pipe. more efficent air flow = more hp.
definatly try playing with your tyre pressures next if you haven't already. it surprisingly does help more than u think as the quicker you hookup and get moving, obviously the quicker your time.
hey i was .02 of a sec off a 13sec pass with the same mods as u.
Originally posted by summoner
with that mph.. a 13 is possible 13.7? who knows i dont think so personally. What mods have you got?
I'm not sure if you mean me or Rob77?
Rob77; has a zorst, EBC (1bar), HKS pod filter, Diff kit, puck clutch.
Rev210 ;mods as per signature thingo' . Check the Wed night drags thread for my 13.8 run conditions. If I had another MPH at the end of the 1/4 I would have had a nice 13.6 not a problem.
skyzer33 : Dump pipe or not Rob77 has got more power than me and better traction potential (Clutch and tyres) , having been in both cars. I'd say his car is 3 tenths faster than mine on a good day and last night wasn't a 'good day' for my car.
BTW I'm not being a mondays expert and saying it should have done this time or that time, I'm just saying that with some attention to the problems of driving it seems the car will run a 13.7 or better some time soon. Just keep chipping away.
But, if you get bored doing the chip away thing, go get the T88 34D setup and all the fruit:D
Well i agree with most of this. I personally havent seen a lightly modded R33 get those times, but now im happy to hear they can!....maybe everyone else is just a cr*ppy driver :(
Um just one thing Rob your keen running 1 bar with the stock cooler! Ive seen R33 turbos blow with less boost pressure.
Anyways good to hear guys.
Ben
I have a cat back exhaust, still running std dump pipe/front pipe and cat. a blitz dual sbc boost controller (set to 0.8bar). HKS pod filter (green one). cusco front strut brace (adds heaps of HP :(. whiteline diff kit (adds traction not HP). 2500Pound pressure plate clutch with 9 "fingers" (again no HP, but no clutch slip). dunlop 225/55 SP9000 tyres (better traction). I'd say at a rough guess I've got somewhere around 180rwhp. I still dont understand how a clutch can be deemed a HP mod, all it adds is more traction and less clutch slip so quicker take-up. I think rev210's onto something big with the 20psi in the tyres jobbie, I think that made all the difference between his 14.3's and then his 13.8. I'll be buying a small tyre pressure thingy and maybe a portable pump so I can pump the tyres back up.
Rob
Ben
Ben, the stock cooler isn't the problem running 1bar it's the dreaded 'pottery wheel' (ceramic) that doesn't like 14 odd psi for long. Depending on where you measure the boost the frount mount does not increase the turbo's tollerence if measured at the compressor. The front mount might show a lesser psi drop at the plenum due to efficiency, perhaps thats what you mean.
I think I'd have my ass handed to me by quite a number of the guys on this forum when it comes to a driver skill challenge.
so whats the issue?
The issue seems to be that Rob has a comprehension problem.
The "Naysayers" only told him that a 13.7 was unlikely from the setup he was running.That setup included other things like clutch/suspension and tyres etc not just HP which he seems to have fixated on.He has set about modifying his previous set up to prove us all wrong but has missed the point (he no longer has that setup)
Rev210 has made a fine effort to get the times he has but he has put some development into his car to achieve it.Congratulations Dude!!!!
Rob
As I recall the only "shit" you received was over your attitude not your achievements thus far.
Before you modify your car further please modify your manner on this forum as I for one am growing tired of your continual bleeting/stirring. That is all I have to say on the matter and will not be drawn further.
This used to be a great forum before the influx of stirrers
Going back to the original thread, I was told that I would need more power. I still havent got more power, I've got more traction. All rev210 and I are trying to prove is that you dont need to spend large dollars on front mounts, bigger turbo's or hiflow'd turbo's, safc's or new ecu's to run into the 13's. You guys said I couldnt and rev210's done it. At the end of the day I respect your knowledge chris, you've driven enough skylines to know whats what. At the end of the day all of us have the same common goal, to get as fast a time we can. I'm just trying to show that you can get a fast time given the small amount of mods I've done, same as dave.
Rob
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
