Well I finally got off my ass and went down to the plex. It's better than ravenswood ever was I have to say.
First run 14.3
Second run 14.3
Third run 21.99999 ---- smoke that clutch baby yeah!
Fourth run 20.00 ------ Bang what the %$#* was that!
Vacume hose blows off thanks to me cleaning the engine bay and not putting a clamp back on the other day. DOH! At least it wasn't my turbo! I had no clamp so I thought it might just blow off again at 10psi so I put boost down to 8psi to see if the next run it would come off again. I managed a 2.1 60ft tho'.
Run No. 5 --- 13.8 / 101mph / 2.2 60ft. Wooo hooo!
Run No. 6 ---- 16 , no more for the clutch tonight time to go home.
For those interested my car has the following handicaps:
1) me driving, my own BO also affects alertness.
2) 100+kg of paper in the boot ( I took some pics of it )
3) Stock IC , ECU (I have no additional fuel management of any kind).
4) El' crapo 205s all round on stock rims.
There you go . You CAN run a 13 with a pretty stock R33, so go out and have some fun trying.:(:D
https://www.sau.com.au/forums/topic/6022-wed-night-drags/
Originally posted by JiMiH
well there ya go! :(
well done mate!
Cheers guys.
I hope this encourages 'our team'. I won't be down the drags again (to race) until I replace the stock clutch (poor things done 90k) and get some tyres a little wider than razor blades.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90889
Originally posted by Gradenko
Excellent time!
For reference, I ran a 13.802/103.68mph, 2.378 60'. Its all in the 60'. You would have rocketed if that 2.1 (60') run had of gone through.
So, gonna get a new clutch to match that flywheel? :(
Yeah I was running 10psi as opposed to 8 so the 2.1 would have got me a 'fat bastard' time. I speculate the ol dunger could have got a 13.7 maybe a 13.6 (with 1bar ) then again it didn't so we will never know.
I actually got the flywheel to go with the clutch, the clutch has been on it's way out for a while ( I carry too much in the boot all the time and try to race people on private roads ). I thought if I'm going to do the clutch I may as well do the flywheel.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90891
Originally posted by RadiuM
very nice times indeed.
who's OUR TEAM?
Skylines vs World.. or
R33's vs R32's..  :(:D
Shaun
You R32 guys have GOTBOOST running 13.7s, the R33 stockie team needs some revving up so we don't fall victim to every silvia that motors past. All the other R33's on the night were running mid 14's exept Rob77 he got a flat 14 from memory.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90897
Don't forget about the 34's hey....13.6 auto;)
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90976
Originally posted by skyzerr33
great time dave
actually the weight in the boot may of helped the car squat more giving you better traction :(
you can't forget you diff kit, and refridgerated stock coola :D
great work. good to see another R33 in the 13's
Thanks mate.
In all honesty the extra weight in the boot probably did help a bit ( I had 3/4 or so tank of fuel too), the weight didn't help the poor clutch. But, really putting extra weight in your car to go faster is a bit wrong isn't it?
The diff kit is an interesting thing too , I have only got the back half installed. Due to my renowned slackness I couldn't be jiggered putting the front section in. It sure has improved things tho' none the less with only more potential to come if I install the rest.
The refridgerated ic I only switched on for the staging on the first and second runs, after that it was pretty cold anyway so I left it off. It was off for my 13 pass.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90977
looking forward to a meet with a decent track prep
everyone was complaining bout traction last night.
that 13.6 or better is gettin near. 13.700 104mph
with heaps of wheel spin into 2nd.
new cooler is in and looks the goods.no more boost spikes
changed wastegate line from turbo comp housing to manifold.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90986
I'm sure you can get the time down at least 5-7 tenths with that MPH, more if you got DOT street racer tyres (should be 12s)
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90994
Originally posted by whatsisname
Congrats Rev :D Nice numbers mate.
Cheers mate.
I still haven't got the concrete in the boot yet. How about you?
You machine should get some nice low 12's with all that new power you have, either that or a good 1/4 mile long burnout.:(
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-90997
Originally posted by Strich9ine
hey rev,
can you explain your "refridgerated" stock coola thinggo ? What the ?
-Kym.
Peltier with heatsink 'devconed' to the bottom of the stock ic.
It's pretty good at cooling between boosted runs. So much heat during boost I can't imagine its any good at improving the HP curve on a sustained run. It's quite handy during hot days like today to minimise heat soak.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-91097
WOW.. someone using PC cooling technology on car's ?
Nice work Rev.
How much did that little system cost ?
Roughly how big are the peltier's ? how are they affixed to the coola ?
This sounds like a TOP idea.... you have any pics ?
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-91121
Nice work Rev.
I think I covered it pretty well on the freehorsepower thread on the SDU forum.
The peltier is a highpower unit but, still only 4x4cm. Its stuck on the bottom plate with bits of metal putty.
https://www.sau.com.au/forums/topic/6022-wed-night-drags/#findComment-91127
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
