  • Replies 58
Someone on the forums has one of those front bars, its a red r32 gtst, i think he has it in his sig along with his mkiv supra.
Thats coco69, 32gtst is currently up for sale http://www.skylinesaustralia.com/forums/sh...ead.php?t=56404 (pics of trial FB here)
I reckon the trial frontbar looks awsome....
I wont ask how you come across that picture pentae, but its not wrong to put a GT-R kit on a GTS or GTS-t, it improves the look of the car as a whole without making the car over the top, i'd rather see a GT-R kit on a GTS-t then an Abflug creation or something like that.
My opinion would be don't bother about the RB25DET
Just work on the RB20DET. I was happy with my GTST, till I went to the circuit, didn't feel fast enough or handle like I wanted. I was lapped by GTIRs for gods sake (JOKES :) )
my mates Evo IV made me feel like I was standing still with foot flat. here are the mods I had on my last car, I sold to some guy I haven't seen since (worries me:( ):
Engine Performance
105, 000KM's. Major service performed by just jap at 97, 000KM's. All other services done by me at regular intervals. Platinum plugs in there and gearbox oil was changed at major service.
3" exhaust from the turbo back. Dump pipe and front pipe are one piece fitted by just Jap
K & N panel filter in the standard airbox. Removed POD that was on there.
Turbo XS Dual stage Boost controller fitted and set for 11PSI on low, 15PSI on high.
Bosch 550HP fuel pump has been fitted as it was leaning out on the standard one.
HKS FMIC Kit bought from japan brand new and fitted. Front bar modified to fit.
Suspension & Braking:
Koni Adjustable Shocks and Lowered springs fitted, Height and Damper adjustable
24MM Front sway bar & 22MM rear sway bar with new D-bushes fitted, and new pin bushes
New Radius Rod bushes fitted and Full Alignment done
Front and Rear DBA 4000 Series brake rotors fitted with Bendix advance pads (last few months)
Motul 600 racing brake fluid
Calipers painted RED
New 17" Work Ryver Wheels fitted, Purchased BRAND NEW. tyres are in good condition. Wheels are, Rear - 9" wide, Front - 8" wide
Interior:
Momo steering wheel and boss kit & Nismo aluminum gear knob
Recaro Drivers seat, decent condition (also includes immaculate std drivers seat as is passengers immaculate) CRD seat covers used all times
Pioneer CD player (entry level deck)
Boston Acoustic Front 6 an a 1/2" speakers
Pioneer 6 an a 1/2" rear speakers
Alpine V-series AMP running all 4 speakers. 350WATT AMP
Greddy 52mm Boost gauge (reads to 1.5bar)
MISC:
Rear Guards Lipped to suit wider wheels
Philips 4300K light globes fitted
10% dark tint on all windows except front
Inbterested to hear about your TD06-19C results. Keep us posted.:)
Provided the tune isnt a hand grenade, and your engine isnt a liability to start with, i think you will have to be trying pretty hard to kill it:)
car lands from jap in 3 wks... the car has 180,000kms on the odo... unsure if engine is newer or not - so im going on the fact that its an ex track car, its gonna be shagged if its still using the motor it was built with...
obviously a compression test is going to prove wether im right or wrong...
if comp test comes up good - im giving it 3-4 months max before motor goes pop - then its neo-6 time :kick:
also the rb20 in my car has tomei cams (unknown duration or lift) so hopefully theyll help with the spool time... as you would know the 19c is only an 8cm exhaust housing so i will be losing a bit of top end compared to a 20/25g... this 19c should max flow at about 260rwkw on 1.5 bar... least my greddy type r bov will vent with this turbo hahaha
ill keep you guys posted
oh and on a sidenote - just temp due to the fact im a bit short on cash... 550cc FC rx7 injectors should last me a lil while for 230 odd rwkw right?
- adz
When you get rid of the engine, i bags the cams...seriously, contact me when you are done with them.
As for the turbo you are installing. "19C" refers to the compressor, and the 8cm refers to the exhaust housing size. The 20/25G alos refers to the compressor wheel size of other Trust turbos, but as they are all TD06 generically have the same turbine/exhaust wheel. Some are TD06, some TD06S, TD06SH etc etc.
And at the power levels you will be running i dont think the 8cm housing will hurt top end too much, especially if you have cams. The TD06 is a decent sized turbine and flows plenty of air, so i wouldnt be too worried. Im actually tryin got shop around for an 8cm housign for my TD06-20G just to compare the results with the two different sized housings:)
So your19C should be more responsive then my 20G as the compressor wheel is smaller so less inertia, and you are also running the 8cm housing rather then the 10cm housing like me.
I have never seen results of the 19C, but my 20G on a std RB20 running 16-17psi makes a comfortable 220rwkws. If the tune was not so conservative i may make a bit more power, i would be very interested if the 19C on your car makes the power you are aiming for on oump uleaded.
Forgot to mention that it now has an R34 GTR FMIC, and an Apex-i N1 GTR turbs back exhaust, plus I fitted a 1100kg 9 puck ceramic clutch.
(And no, I dont want a GTR, parts cost too much- bar a std cooler which i got for a good price, and I have enough fun in my GTS-T!)
Reliable fun :)
Steve
Pentae have u ever conisdered that people who have gtst can afford a gtr but choose not to buy one? or have you considered the reasons i am fitting the gtr bonnet and rear spoiler, that is to lower weight and increase downforce ???
or are u a narrow minded bogan whos opinion no one values anyway??? :flamed:
should be a hard one... anyone???
Although some people disagree, I think fitting GTR bits to a GTSt is ok. I prefer the GTSt rear spoiler (on a GTSt :)) but the GTR grill and bonnet looks horn on any R32.
If I'm honest with myself, if I owned an R33 GTR I wouldn't feel bad fitting a 400R bodykit to it.
Each to their own, whatever starts your engine and all. That said, I still laugh at the Civic-spec "R34 GTR" that was for sale on eBay a while back. Oh yeah, and the SerIV RX-7 on Prestige's website that has the Ferrari bodykit.... and the MR2 on J-spec with the Ferrari bodykit.... *groan*
Dude, relax. Rise above having a go at people. Choose to disagree and leave it at that eh?
Mark
roy - thanks for the refresh but im fairly up to speed on trust ID figures :P
generally all 19c's came with an 8cm housing so...
but moving along - only 220kw? very conservative tune... and 16psi isnt really in the turbos efficiency range (borderline opening the door to the G spot of the turbo)
20g will max flow at about 290-300kw... so youve got another 80kw if you ever need it sitting up there in the top end (around the 24psi area)
- adz
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
