Hi, I am thinking of purchasing my mate's r32 gtst, and it has the old scholl air con unit, not the newer climate control. What I want to know is, is it possible to install the newer r32 climate control module, as I have gotten used to it in my r33? Has anyone done this before. I know it is pretty pendantic, I just like the control that climate control allows for.
https://www.sau.com.au/forums/topic/60250-r32-climate-control-installation/
Pedantic???? That's one word for it. Luckily, it is probably not practical to convert. Prob some wires missing from loom, etc.,. If you ever get some of the weird problems that the Climate Control can throw at you,just in order to not have to turn something up, down or off, you'll wonder why you wanted it.
yeah.. it might be a "non mspec" thing.. or just a factory option that is 95% optioned on...
I got the old sliders too.. I know they work, but hell, I like the digital thingo, makes you feel like you have a fancier car (pedantic I know).
I picked up the control unit and the loom for $100 to do the conversion.. I have had a quick look, and it looks like the slider controls actually have the old-style cable mechanism which opens up the various flaps near the firewall. This makes it tricky, as I think the newer method works with actuators (like the R33) to open the vents, etc. So I'll probably need the actuators to actually do it. Looking more and more expensive.
I can't find out too much information either on the conversion, other than for the S13, which I assume it could be similar to.
I really have to pull the whole dash apart to find out what sort of task it is.. not high on my list of priorities right now.
Hmmm... well guess i'm just thankful i have the Climate Control, however, if they were an option i can't see it being a massive task to fit on after the fact. After all the factory had to do it and it'd be woefully ineffiecent too make really to do (altho if it's ALL behind the dash that's much easier with a partially assembled car).
Good luck.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
