I just had the O2 Sensor Replaced a few days ago, the fuel economy is much greater then before.
Also, this Car comes along with the standard Exhaust system and Standard Airbox, for those annoying EPA ppl.
This Car has to go soon, so guys dnt miss out on this one.
Im sick of time wasters as you all know how it is, so please dnt waste my time by asking for the color code, or where i got the bodykit done, it is for me to know and for you NOT to find out. :cheers:
Any interested buyers plz forward me an email.
Willing to take offers now, (no rediculas ones, this aint e-bay, so the auction isnt starting at $1)
Genuine offers over $18000 Will be considered
Can negotiate, depending if parts need to be removed, such as wheels, exhaust, system, we can work something out.
Cheers
Once again pics have been posted out, look people if you like looking at hot cars but are not keen on buying them ill give you a good spot to check out and not waste othe ppls time go to www.cardomain.com and select your desired car, but quit wasting other peoples time.
The car is now officially for sale its in AUTO SUPER MARKET/Car point.com and tradingpost.
So if any of you ppl are interested or got someone of your friends who would like to buy a SKY, plz refer them to me, my new number is 0422 34 6767.
ALL REASONABLE OFFERS Will be considered, due to a few financial probelms i have now.
  • 3 weeks later...
hey mate i might be interested if you can got to about $16000, you can take all the mods out of the car wheels FMIC ect, that dont bother me, it will all get replaced
email me if your interested...
[email protected]
[email protected]
i have again someone chasing finance, this 2nd time now, so im not sure if they will buy it or not.
but for me to drop down to 16grant would mean the mods below to be removed, and i couldnt replace them with standard ones, you would have to accept it AS IS, and replace the parts yourself.
FMIC<< i dnt want to remove due to its hard to sell them things, and they are cheap.
Following Mods that im willing to remove:
TEIN Adjstable suspension
Wheels
Exhaust
Stereo
Removing this parts i could drop it down to 16grant.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
