Well I'm gunna have a serious go...
is it ok to remove all the pipes from the turbo to the soilernod
What solenoid? Is it stock? Or part of a boost controller? Why do you want to remove all the pipes? Pics...
as i put a boost controll on and i run it form the turbo to the wastgate
What do you run from the turbo to the wastegate? What boost controller?
and can you tell me what some cheap things to do to my motor is to make it faster
Define cheap... Whats done ATM?
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1145274
DIY: Boost Controll
Many of you may have been fooled into buying bleed valves, in some cases even expensive electronic items. All i can do is frown at this behaviour. You have all you need to make your own at your local hardware store! What your going to need for this exercise is a piece of vacumm hose, prefferably long enough to reach from your actuator to near your pod or airbox and a screw (pictured below) and a screw driver (philips head)
After obtaining these items you need to decide one of two things. Just how much boost do you wish to run and whether or not you want to be able to adjust it.
OPTION 1) Run the vacumm hose off your actuator with no screw in the end. This method is very effective performance wise, however it MAY lead to destuction of things such as your turbo. Not to worry fuel cut will save you. This method shows how truly hardened you are and indicates just how much boost your stock turbo can handle before literally throwing chunks of the exhaust wheel out your exhaust. Some may view this method as a little extreme even though it has proven promising on certain cars . Not to worry option 2 is for these people.
OPTION 2) This option is for the light hearted. You take your vaccum hose and bring it all the way to near the pod. You then use your screw and screwdriver to implant the screw in the hose. (seen below) The further you screw it in the less boost you will run. To get maximum performance we suggest road tuning, to optimise the boost level.
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1145330
what are we looking at in the first two piccies??
am i correct in assuming it's the vacuum hose coming off the actuator??
i hope no-one has done this to their cars. seems seriously dodgy to me.
lol yea, as josh said we did it to his car and it held boost suprisingly well. And his Apexi boost controller was crap and didnt work, who wants to go around on 7psi, something had to be done and this was it. Dodgy? yes. dangerous? probably. Did it work? You bet ya...:(
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1151628
interesting.
just let me know how long your engine holds up and i'll consider doing this to my car.
though i suppose it sure beats spending hundreds of $$$ on electronics that don't want to work.
I have now sold the car; I had this dodgy item on the car for around 6 months with no signs or ware and or damage.
As it was only holding 12psi.. There should be any difference between that, and 12psi on a real controller.
I had a compression check down before the new owner got the car, and all was fine. The turbo was in ok condition for a car with 140,000kay.
https://www.sau.com.au/forums/topic/60262-rb20det/#findComment-1152000
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
