As the title says im after as much accurate information on my car as i can possibly get in the way of mechanics,measurements,performance etc etc on the stock car.
Ive tried searching but i must suck at it coz i couldnt find anything like a page with all the inof im after,so if someone could tell me where to look that would be great
Cheers in advance
Nissan Skyline
Model Variant GTS25t type M
Year August 1993
Body Type Coupe
Seating Capacity 5
Engine Code RB25DET
Engine Type Inline 6 cylinder DOHC 24 valve IC turbo
Engine Size 2.5 litres (2498 cc)
Bore × stroke 86mm × 71.7mm
Compression ratio 9:1
Fuel system
Max power 184kW @ 6400rpm
Max torque 294Nm @ 4800rpm
Forced Induction IC equipped turbo
Fuel Tank Capacity 65 litres
Fuel type Unleaded premium petrol
Fuel Consumption 9.8 l/100km
Transmission OD attaching 5 speed floor shift
Drive Layout FR
Steering Type Power assisted rack & pinion
Front Suspension Independent suspension multiple link system
Rear suspension Independent suspension multiple link system
Front brakes Ventilated disk
Rear brakes Ventilated disk
Front tyres 205/55r16 89v
Rear tyres 205/55r16 89v
Turning circle 10.4 m
Exterior Length 4640mm
Exterior Width 1720mm
Exterior Height 1340mm
Interior Length 1820mm
Interior Width 1415mm
Interior Height 1090mm
Wheelbase 2720mm
Front Track 1480mm
Rear Track 1470mm
Ground Clearance 145mm
Weight 1360kg
Standard features Limited slip differential, Rear spoiler, Rear window wiper, Rear seat lap sash belt, Side impact protection bars, Power windows, Central door locking, Steering wheel height adjust, Leather steering wheel, Alloy wheels
this should keep ya happy.
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
