Hey Guys/Gals....I'm tryin to post a couple a pics of my ride.....Still new to the forums so be nice :Oops: Lemme no what u'all think....Also, the pic of the rear wheel - currently running stock 17"s, I'm thinkn of 19"s but dunno if they'll fit the current body kit (the gap from tyre to kit is quite small).....Any ideas?? Thanx in Advance ppls!! :cheers:
https://www.sau.com.au/forums/topic/60324-cuple-of-pics-of-ride-r34-gt-t/
Did someone say bannana :)
Nah seriously, how can any skyline not look good :)
What you will find is, if you go to 19" the tyre profile gets smaller as the wheel size increases, so overall your total wheel/tyre diamater wont change much. Probally +15mm at most. Pending on tyres.
If you lower it, the arches and kit will sit more around the wheel too, if you get what i mean, so you will get a tad more clearance.
Just make sure you get the correct wheel offset to suit the GTT, or else the wheels will scrub all the time.
If you fit bigger wheels, or even if you dont, a mild lowering job will improve the overall stance of your car ten fold.
Cheers
Did someone say bannana :P
Nah seriously, how can any skyline not look good ;)
Cheers
Ta mate.....Good advice me thinks....By a mild lowering job, what do u guys recommend?? I love the ride of the car atm and don't wanna lose too much of it....I've been recommended coilovers, but don't want the car too stiff.....Is there another, maybe cheaper option which I can look to have my car lowered, but at the same time, not lose too much of the comfort??
Nice car - Top Secret Front with C-West Sides and Rear :P
Some lowering springs would be cheaper (and better) than full suspension for everyday driving (unless you like to drive on race tracks?) - I use Trust Dowmax (35mm drop) but any make should be OK
The best offset's for new wheels :-
+35 to +38 on 9inch wide Rear wheels (will take 265m wide tyres)
+32 to +35 on 8inch wide Front wheels (will take 235mm wide tyres)
This is how mine looks on 18inch wheels with those offsets (ps I've modified my TS front too)
great looking car mate.
I think the height is enough as with the kit the car looks low to the ground so if you go lower then you will struggle to get into some places (if you dont already).
I reckon you put 19's (will look very sexy then) on it and then decide on ride height.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
