This is your chance to purchase the best developed Street/Circuit R33GTR in Australia (World??)... THe result of 3 years ongoing, no expense spared development by RacePaceMotorsport, this car is blindingly quick, quiet and fuss free. RB31DET, 500kw @ tyres, laps Sandown in 1m15s, Calder in 59s, (using road legal 'R' tyres)...phenomenal performance with road car drivability/reliability...
Engine.
RB31DET
Forged Pistons
Carrillo rods
Custom Plenum
1000cc injectors
etc etc..
500 kw @ tyres 1.4 bar boost premium unleaded
Turbo.
Custom Race pace Garrett 1000hp
Transmission.
Triple plate clutch
OS Giken cross mission 5 speed
Diffs.
OS Giken rear LSD
ATS front LSD
Suspension.
Top shelf Race Ohlins
RacePace Custom springs/valving
Extensively developed Attesa system
Brakes
F. 385mm rotors , 6-spot Harrop billet endurance Calipers
R. 335mm rotors, 4 spot Harrop calipers.
Wheels, tyres
18" x 10.5" Volk TE37
Bridgestone RE55 285/30/18
Plus way too much more to mention.....
Serious enquiries only as this is a seriously fast car......If you want to dominate track/club days then this is what you need........PM me for further details..
If you want pics, just search this forum.
Looking for geniune offers around $120k
May consider a good road car as part trade.
https://www.sau.com.au/forums/topic/60336-racepacemotorsport-r33gtr/
Hey Guys,
Was possibly looking at an R34, but have a 200awkw 01 wrx for sale and maybe this R33 is up my alley..
Can you please send pics to [email protected] or let me know what search criteria I should use to find this car?
Cheers,
B
search for "Ben Racepace" or somethign similar...
here's a thread to get you started...
Skyline GTR breaks Sandown Marque Lap Record
http://www.racepacemotorsport.com/rpmgtr.html
If you are genuinely interested, ring Ben on 9762 9421 and arrange a time to see the vehicle.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
