hi,
i recently got a r32 gtr and i dont know if i have a problem or not.
when i take off slowly it shudders a bit like something is slipping.. but if i get the revs up a bit higher and take off it doesnt slip at all.
i have been told that it could have a tripple plate clutch?
also the gear box is very loud, in 1st 2nd and 3rd it make a prety loud winding noise. could it be after market or is it normally like that?
one more thing... when i turn 90 degree corners the inside wheel skips, does tnat mean it has a locked diff also? or is that normal
https://www.sau.com.au/forums/topic/60343-gtr-questions/
From what youve said it sounds like theres a bit of work been done to it, but dont want to jump to conclusions.
Does the clutch make a metallic ringing noise when you push the clutch pedal in? Also if it was a gearbox bearing, you would assume the gearbox would whine in all gears. Judging from everything else youve said, I wouldnt be suprised if it had straight cut and/or dogged 1st 2nd and 3rd gears.
As Morgs said, what else is done to the car?
https://www.sau.com.au/forums/topic/60343-gtr-questions/#findComment-1146146
there is only an exhaust from turbos back and slightly bigger frount mount and lowered.
it doesnt whine in other gears, well i cant hear it so it might, but just not as loud.
when the clutch is out and im in neautral the gear box/clutch makes like a loudish grinding type noise (not THAT loud), it goes away when the clutch is in, and when driving it makes a whine noise..
the clutch is also close to an on/off clutch.. there isnt much to ride if you get me. and shudders when slowely taking off, and inside wheels skip when turning
https://www.sau.com.au/forums/topic/60343-gtr-questions/#findComment-1146178
If its got about 2 - 5 cms from the floor before enguaging its a aftermarket clutch. Its either ON or OFF no riding it :) - other wise bunny hop time!
The throwout bearing makes a wineing noise with the clutch out on idle ?
If you'r diff makes a clicking/ticking sound when you turn - going slow then its a locker diff.
https://www.sau.com.au/forums/topic/60343-gtr-questions/#findComment-1146202
well i would say its an aftermarket clutch then.
i cant hear any ticking noise, just the tyre skidding.
i just dont want anything to be wrong with the gear box.. it drives hard and doesnt perform any less then it should, just has some concerning noises
https://www.sau.com.au/forums/topic/60343-gtr-questions/#findComment-1146243
Guest Mashrock
its a multiplate clutch for sure which makes the ringing noise when you push the clutch in. nothing to worry about really..
tho it could be worn?? maybe you'll have to pull gearbox off to find that one out
the skipping wheel for tight turns would be a tight lsd i gather??
the other gear box noises i have not a clue about.. get them check out by someone who knows what they are on about.
https://www.sau.com.au/forums/topic/60343-gtr-questions/#findComment-1146803
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
