A few days ago my car died.. FarK! ended out being that the Microtech computer (MTX-8) was fried because of some dodgy wiring and one of the battery terminals arcing to something.
I really didn't like the Microtech anyway as it always had trouble starting (like 3/4 separate attempts to get started with a constant idle - oh and it was tuned properly) and although once on boost and high in the rev range it made a lot of power and pulled hard it's drivability off peak was not that good.
I was told that this was because the Microtech used a MAP sensor and it was a pig to start etc due to the vacuum pressures in the inlet manifold.
Anyway.. here I am now forced to save up and fork out a whole bunch of cash, which straight after Christmas kind of sucks.
I have been told that if I go to a Power FC that I'll basically be able to reach through the window turn the key and the car will start perfectly and that drivability will be far superior.
Sounds good.. the only thing is that I will need to purchase an original r32 wiring loom and two Z32 airflow meters which in the end of the day = $$$
Question: Do I bite the bullet and go the Power FC or is there any MAP sensor ECU's that actually retain some sort of drivability, without spending a fortune on a Motec!
Thoughts, information would be appreciated as this has really stung me and I'd like to not be ripped off and just get the car back on the road asap
https://www.sau.com.au/forums/topic/60344-gtr-computer/
Cheers I appreciate that Pawley.. though because I don't have a standard loom fitted I can't use just at the moment.. never the less perhaps I could borrow rent from you once fitted to give me a few weeks to save for the Power FC, though does the R33 GTR ECU retro fit and operate a R32 GTR?
https://www.sau.com.au/forums/topic/60344-gtr-computer/#findComment-1147824
get a microtech L10S.. brand new. perfect for RB engines.
https://www.sau.com.au/forums/topic/60344-gtr-computer/#findComment-1147831
7heaven - cheers I'd love to save the cash.. though my understanding was that Z32 air flow meters allow a higher resolution electrical output than the RB20/25 AFM, am I wrong in thinking this.. are these items just as good?
Since you have all the loom and NO AFM's. Run the new LT10S.
Trust me.
Cheers
https://www.sau.com.au/forums/topic/60344-gtr-computer/#findComment-1147851
The z32's are better but unless your planing on running close to 400kw at the wheels then the rb20/25's will do the job well .
https://www.sau.com.au/forums/topic/60344-gtr-computer/#findComment-1147897
yeah a 33GTR ecu will work in a 32GTR. One other option is a PFC DJETRO, it uses a map sensor so no need to pay for two new MAF meters then. you still need to replace/repair your loom though.
https://www.sau.com.au/forums/topic/60344-gtr-computer/#findComment-1147933
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
