Gtr Computer
A few days ago my car died.. FarK! ended out being that the Microtech computer (MTX-8) was fried because of some dodgy wiring and one of the battery terminals arcing to something.
I really didn't like the Microtech anyway as it always had trouble starting (like 3/4 separate attempts to get started with a constant idle - oh and it was tuned properly) and although once on boost and high in the rev range it made a lot of power and pulled hard it's drivability off peak was not that good.
I was told that this was because the Microtech used a MAP sensor and it was a pig to start etc due to the vacuum pressures in the inlet manifold.
Anyway.. here I am now forced to save up and fork out a whole bunch of cash, which straight after Christmas kind of sucks.
I have been told that if I go to a Power FC that I'll basically be able to reach through the window turn the key and the car will start perfectly and that drivability will be far superior.
Sounds good.. the only thing is that I will need to purchase an original r32 wiring loom and two Z32 airflow meters which in the end of the day = $$$
Question: Do I bite the bullet and go the Power FC or is there any MAP sensor ECU's that actually retain some sort of drivability, without spending a fortune on a Motec!
Thoughts, information would be appreciated as this has really stung me and I'd like to not be ripped off and just get the car back on the road asap
I have my old 33 GTR ECU sitting in the garage (Adelaide) that you could borrow/ purchase to get you back on the road until you save up.
It made 208rwKw with standard boost, pods and cat back exhaust.
Paul
Cheers I appreciate that Pawley.. though because I don't have a standard loom fitted I can't use just at the moment.. never the less perhaps I could borrow rent from you once fitted to give me a few weeks to save for the Power FC, though does the R33 GTR ECU retro fit and operate a R32 GTR?
get a microtech L10S.. brand new. perfect for RB engines.
7heaven - well I'd love to save the cash.. though my understanding was that Z32 allow a higher resolution electrical output than the RB20/25 AFM, am I wrong in thinking this.. are these item just as good if not better?
7heaven - cheers I'd love to save the cash.. though my understanding was that Z32 air flow meters allow a higher resolution electrical output than the RB20/25 AFM, am I wrong in thinking this.. are these items just as good?
Since you have all the loom and NO AFM's. Run the new LT10S.
Trust me.
Cheers
The z32's are better but unless your planing on running close to 400kw at the wheels then the rb20/25's will do the job well .
I have a 32 ECU running my 33 GTR (albeit a little tweaked).
If you want to get a sparkie to fix your loom..... use my ecu for a bit, save up the $$$ for the FC (dont forget how much tuning will cost you, my guess is around $500)
yeah a 33GTR ecu will work in a 32GTR. One other option is a PFC DJETRO, it uses a map sensor so no need to pay for two new MAF meters then. you still need to replace/repair your loom though.
 Share
    • The best part of my setup is, we only have two sites. Our head office where I'd put every thing has plenty of internet capacity. We're on a 200/200 dedicated fibre. Even better, there's only like 6 people in the office at most, and the other office has 2 people in it (likely 3 soon). The majority of our work is in a custom piece of software, as it is part of the backend of the system we provide to customers. For our arrangement, on prem would be wayyyyy easier, and a VPN tunnel site to site is easy for me to manage. Scaled at many many sites, or quite a few hundred employees it's starts getting a bit different for all people outside the head office. However, everything in the cloud becomes worse for the people who operated previously at the site that held the servers, as now they're at the mercy of their internet, and not GBPS internal network (f**k the idiots who hook a desktop PC up on WiFi or permanently sit at a desk using a laptop and don't go remotely with it).   It really does come down to the business needs and structure as to what is best. For us, 365 is mainly being moved to for office apps, moving email from Google to Exchange, and setting up "Active directory". Otherwise we have a ticketing system with support that runs on our own cloud system, or the sales process sits in a CRM we pay for. My biggest push back for having most of the shit turned off and saying no when people want new shiney things is "that won't meet our security requirements, or efficiency gains, so all you're requesting is money spend to open us up to security issues, or to make our staff less efficient" Which is funny when one of our core values is "To do more, with less"
    • Think of it as a fancy iFrame with the auth passed through to PowerBI as you're already authenticated logged into Teams   I'm the complete opposite, I hate everything on Prem, it's slow as shit, you need VPNs to get anything happening, then when you want on-prem DBs to talk to say PowerBI you need to install/setup data gateways to essentially VPN back into your SQL instance. I suppose from my perspective, on-prem sucks, but from an infrastructure perspective, your environment is somewhat air gapped to the web via your firewall(s), etc.   The curse of knowledge, the more you know the more you suffer. Farken philosophical shit.
    • Would you mind uploading the pics again in your steps?  It’s not showing up.
    • Wherever you ask them to. I had one added to the crossover pipe near the BOV as well as the hot and cold sides of the intercooler piping to provide greatest flexibility in measuring temperatures post-turbo. I have the IAT installed in one, and bungs in the other two.
    • I found the rear tailshaft for ABS from skyline spares
