2-3 k respray is very possible. Most workshops have quoted me 2.5k and I've seen their past work.
I wont be spending 10k on a respray unless i'm going to park the car in the garage and not drive it. There's no point in doing a 10k respray driving on the freeway everyday and getting stone chips. I'd rather spend 2.5k on a respray and the rest on some wheels and performance.
I didn't ask you to recommend me to go to tafe to spray the car myself.
If you dont have a proper suggestion then dont bother posting at all.
I already have a university degree so you can get ******
Thats the pot calling the kettle black, Funny how most tradesmen go through TAFE to only "supplement" their learning, yet the knob with a degree, has to call on these lesser mortals to do a Professional job on his car.
The way it works around most places is, you get respect through your quality of work, not through the pieces of paper that you have framed sitting on the wall.
Cheers
Sumo
well other subjetcs aside .. regardless of how funny they are!!!
i did my spray for $1600 .. however i did all the work of preparation myself. this was 1.5 years ago and havent had any problems with cracking or peeling or fading!
half of that cost was in the booth and spraypainter .. the other half was in paint.
if you have time and an alternate form of transport you could do it your self.. if your not inclined that way do a shop around of who will just spray a car that is already prepped if you buy paint .. then find out who will prep a car and not paint it .. ppl may round off the price due to doing the complete spray!
in regards to the kit .. well put them on yourself and that wont add any cost .. plus you wont be spraying the old stuff so the wing and front bar isn't a consideration really (other than aftermarket front bars seem to use more paint)
good luck with the hunt!
http://www.skylinesaustralia.com/forums/sh...ead.php?t=60248
im in the same situation as you im gettin my repsray done for around 1.5k (white, my car is already white).with me adding a new front bar and side skirts im gonna put ma car into the shop in about a week or so to get the job done ill tell you how the job goes wen i get my car back in a few weeks.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
