Hi Guys :)
PIPING
Good news piping will be arriving in australia in ~ 1 month for the s13, R32 and R33. More info and hopefully pictures will be available new week. So if you want to book your kit then reply to this thread. They will be
$500/kit for 10 or more buyers
otherwise $525/kit
Contents
This kit will include stainless steel mandel bent piping, the silicon joiners and the little bits and pieces to lock and tighten it down. Basically it will have everything you need except for the cooler.
Piping will fit the coolers I sell you.
INTERCOOLER
My supplier stocks these intercoolers
600mm x 300mm x 76mm and the
450mm x 300mm x 76mm.
Group buy will be as normal for the coolers as they are in brisbane and can be shipped immediately.
Intercooler Prices
LARGE
Size: 600mm x 300mm x 76mm
up to 5 buyer: $330
5 to 10: $300
10+: $295
Size: 450mm x 300mm x 76mm
SMALL
up to 5 buyer: $325
5 to 10: $295
10+: $290
postage $25 to the east and $30 to the west of australia.
Design
These coolers are from same factory the hybrid get their cooler manufactured. So if you like you can call them a copy or a hybrid cooler without the badging up to you. So they are exactly the same design/quality/performance as the original hybrid coolers. The specs you see on those intercooler also applies here..
Here are the specs
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
PACKAGING
As seen in the picture the cardboard box has polystyrene strips to protect the fins from transport damage. The cardboard box is even double up in places for extra strength.
PAYMENT
Payment must be by Direct Deposit.
Local Pickup is available. Save postage
ANY DOUBT?:angel:
If you have doubt about buying from this group buy do a search for other groups buys with my name. Im sure you will find out quickly Im an honest bloke . Also if for some rare reason I can't get the parts and you have already transferred money to my account your money will be transfered back to your account straight away!!
ADMIN
To make admin easier for me as Im prediciting there will be a lot of people wanting these kits. When you reply can you please tell me eactly what you want in this thread. Example
"large cooler
pipiing kit r33"
"piping kit r32"
"large cooler"
Thanks guys any question feel free to ask me.
COST REDUCTION
If you buy a cooler and piping I will be able to knock off some cost of the postage. So ~20 saving will be achieved. :)
PIPING KIT BOOKING
R33
1) Mr.R33
2) LANFOH R33
3) Damien
4)
5)
R32
1) Sheepy R32
2) jager R32
3) z3n2k R32
4)
5)
S13
1) SuperGimp s13
2) Seth s13
3)
4)
5)
COOLER
1) Damien R33
2) Mr.R33
3) SuperGimp
4)
5)
6)
https://www.sau.com.au/forums/topic/60383-intercooler-and-piping-kit-group-buy/
  • Replies 116
how big is the piping kit. 2.5 inchs or 3 inchs? And will the fan blades need to be cut? what type is it, the one that goes under radiator or the one that goes over engine?
i'm interested in an r33 piping kit pending the answers to these questions. I was goin to go in the other gb for piping but i don't think i'll have the cash by the closing date. Just keeping me options open. :P
thanks.
Rom.
My intercooler arrived this morning. It's the hybrid limited edition ;)
Solid construction, nice polish. I'm not sure what, apart from the cool looking plaque, make it different to the others, probably nothing.
Once it's fitted it will be impossible to see the plaque anyway.
I can highly recommend these coolers. :P
Thanks Raf
  B0oStEr said:
My intercooler arrived this morning.  It's the hybrid limited edition :D
Thanks Raf
another happy customer ;)
I have one limited edition at home and I will line it up with the other ones at the suppliers house - see if there is a difference. But your probably right! Just a cool plaque. Anyway atleast you can tell your friends you a a limited edition hybrid cooler :D
I have received more info.
I will have 5 R33 kits 5 r32 and 5 s13 kits They will arrive inthe first week of feb.
All pipes and hoses are 3 inch. Blue silicon hoses and Stainless clamps.Same as a hybrid kit
Pictures are not available yet.
So for you guys who want to book a kit please do so as I have limited numbers for the first batch. No money is necessary at this stage.
All kits will be $500.
Guest
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
