Insurance concerns?????
IMPASN
 Share
If you're not going to list your mods, then might as well not get insurance. The company will surely try to get out of paying any money by saying "we didn't know you had those mods, so we're not going to pay". Apparently Just Car are like this, hence you have to list everything.
As for needing comprehensive, I've heard that you do, but don't quote me on that.
yea i have been told with all banks that i initially went to get a loan was that you will need it comprehesivly insured as that way if you write it off and cant pay back the loan the bank will just take the money from the insurance claim...
also tell them everything thats on your car as r32skyliner said you had may as well not have insurance otherwise.
on that note i had better update my policy :D
thnaks 4 that fellas. What i ment b4 was by not listing all the mods the insurance may b cheaper! like i would list important things but stuff like race wheel an stereo wouldnt really worry bout. I know they wont cover u if its not lisited but im hardly plannin on have a smash... if u know wat i mean :D My mates pulsar sss got an exhaust system thats not covered, he plans on rippin it off if it comes 2 that in an accident.
Guest Mashrock
2 questions that i would love some help on r...... If i take a loan out 2buy my skyline does that mean i need full compo insurance an the other is should i list mods or take the gamble without listing them!!!!
depends. if you take the loan out as a car loan then yes they want you to insure it.
but if you take the money out as personal loan then you dont need to do so..
With an automotive loan, you are required to take out comp insurance on any mortgaged property ( the car ) as the car is the security. To qualify for a personal loan you must display affordability and a proven repayment plan of some form of previous payment, or be assett backed. ( home owner/buyer ) if you don't supply a certificate of currency for a secured loan you will not be approved .
As for insurance!!!!!! There is a matter of whats called (duty of disclosure)
meaning if you do not list all and any mods and accessories to the enth degree ANY insurer can and will decline to honour any claim made for whatever reason.
These parameters are not negotiable from lenders and insurers.
Pay the money and get the correct coverage or change vehicles to a lesser risk vehicle.
 Share
    • Hey Matt, Link pointed to the 2x IGN power sources from the car as a likely issue, and sure enough pin 31 in the loom does not have power when IGN is on (24 does). So at the ECU, (and this is probably the case for R32 as well as C34) most of the ECU loom goes through the firewall behind the blower motor and there are 2 plugs (of 3 in the junction box) which go up and under the dash, the third plug heads under the carpet to places unknown (likely a body to dash loom joint) So, I started to follow that problem through yesterday. Like Johnny (and R32) I assumed that power was supplied through the 2 connectors near the left headlight so I spent some time pulling the intake etc off and cleaning of 400,000klm of dirt and oil leaks and checking those pins, but there was nothing related to the engine parts or ignition fuses there (and no purple with white trace wire in either side of the connectors) Given that the wire didn't seem to go via the engine bay, I then checked there is continuity from Pin 31 to the second connector to confirm no wiring issue in the ECU loom (it looked likely, given how much that has been hacked up over the years!). The pin marked with the purple dot is the other end of the wire to Pin 31 Then I check for IGN power in the dash loom side of that connector with the key on. Nothing. Given that loom goes up and underneath the top of the dash there is no tracing it without taking the dash out, so I went to the driver's side to see if I can find the other end of that (I'm expecting to get to big body junction boxes after I pull enough apart). However, to get to those functions, I had to pull the covers off the drivers side, I'm pretty sure the problem is in this pic Yep, factory remote start (bottom right), local immobiliser (middle) surrounded by 20 years of butchery. Plan is to totally remove the remote start and immobiliser (I think I will lose remote central locking temporarily as a result) to remove all the suspect stuff given I have other more modern security in the car It's gonna take a while, and it is both cold and uncomfortable out in the shed, not looking forward to it.
    • Hey team,  The clutch on my newly bought 25 swapped r32 feels average and sticks half way. Went to go order a new clutch master but it does not look like the ones that suit the one that’s in the car…    does anyone know what clutch master is this just by looking ?  (The feed is on the side rather than the bottom like the ones the pop up online)  thanks guys new to the RB scene so any help is appreciated cheers !!
    • Id be more than happy to sign up!!! Where do I send the invoices for my fuel usage? I'm happy to provide the mower, oil, and the labour to abuse the motor, just a little help on fuel would be great...   I had tipped the container of oil out into my big "drip tray" and left the small container upside down to drain the oil out of itself overnight. PIcked the container up today, and it has a layer of what feels like either dirt, or shit tonnes of carbon in the bottom of the container. I'm leaning towards it likely being dust, as I doubt the quality of the Sunli BumbleBee having a decent air filter on it, and sections of my yard produce a dust storm, especially because of the high lift blade!   So, filled her up with some fresh Nulon. Seemed to run fine, but it seems to want to run at really high RPM (higher than normal) even with the governor spring slacked off after fire up to try reduce it. If I back the throttle off it a bit to drop the rpm to where I'd like it to be when mowing light grass, it starts to blow a bit of smoke out the exhaust. Opening the throttle back up clears that out. It's definitely breathing oil, as I put my hand down at the breather hose and it's spitting some oil.   My guess is it having been running at high rpm, oil never changed, and it eating dust has destroyed the rings. You know what that means? Time to send it!!!
    • That is what will seal with the bonnet closed. Follow it down while closing the bonnet to see where it ends up with the bonnet closed. The panels don't do anything other than spending money, which this one will do just fine. :p
    • Nah just send me a photo or a drawing and I'll tell you which is better.  It's a new SAU service.
