HI all I know their is an easy way to upgrade the brake but unsure of the process
Do 4 pot calaipers off a R32 fit straight on the cefiro or do you need the disc aswell??
do you just get the disc redrilled for a 4 stud??
whats is needed for a 5 stud conversion?? front and rear??
any other help or if their is a topic already open would be great
Andrew
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/
Im also interested in whats involved.
Also are s14 and r33 rotors and the 4 pot calipers from either the same (as in size, diameter)??? They look it.
Do i source s14 hubs or R33 hubs???
Do you need the lower control arms from an s14/r33 to do the front hubs?
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/#findComment-1148116
If you want to keep the 4 bolt pattern (as most do), then you will need to redrill the discs
For the front brakes, you can upgrade these fairly easily to R32, R33, S14, S15, GTR
You will need to:
remove old disks and calipers
redrill the disks
remove or trim the disc backing plates
fit the new disks (fit straight on)
fit calipers (bolt straight on)
grind a couple of mm off the original banjo bolts
fit lines
all done
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/#findComment-1148444
