HI all I know their is an easy way to upgrade the brake but unsure of the process
Do 4 pot calaipers off a R32 fit straight on the cefiro or do you need the disc aswell??
do you just get the disc redrilled for a 4 stud??
whats is needed for a 5 stud conversion?? front and rear??
any other help or if their is a topic already open would be great
Andrew
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/
Im also interested in whats involved.
Also are s14 and r33 rotors and the 4 pot calipers from either the same (as in size, diameter)??? They look it.
Do i source s14 hubs or R33 hubs???
Do you need the lower control arms from an s14/r33 to do the front hubs?
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/#findComment-1148116
If you want to keep the 4 bolt pattern (as most do), then you will need to redrill the discs
For the front brakes, you can upgrade these fairly easily to R32, R33, S14, S15, GTR
You will need to:
remove old disks and calipers
redrill the disks
remove or trim the disc backing plates
fit the new disks (fit straight on)
fit calipers (bolt straight on)
grind a couple of mm off the original banjo bolts
fit lines
all done
https://www.sau.com.au/forums/topic/60487-upgrading-brakes/#findComment-1148444
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
