Hi guys - well I had caster rods replaced prior to xmas, but only found out yesterday that they were adjustable BUT the wheel alignment hadn't been done SO I had the caster rods adjusted today and the wheel alignment for all 4 wheels done at Wilkinson Supsension in Bayswater...
All I can say is that if you haven't had this done to your Stag and you are concerned/complaining about light/sloppy steering then DO IT NOW! :)
The difference to the weight and sureness of the steering is outstanding - the car now feels like a car rather than a mini-bus/kombi. It feels much more sure-footed and way more confident going around corners and more responsive in quick changes of direction etc
For around $400 for parts, fitting and alignment, it is certainly money well spent. Highly, no not just highly, a MUST recommendation!
(Thanks to SK for raising the caster arms in his Suspension thread!)
:D
No problems, what I can, I share.:(
For interest sake, what wheel alignment settings did you end up with?
Front
(full stop should be degrees symbol)
Partial Toe: L+0.09 R+0.09
Toe: +0.18
Set back: -0.39
Camber: L-0.39 R-0.35
Camber dif.: +0.04
Caster: L+5.49 R+5.20
Caster dif.: +0.28
King Pin: L+15.24 R+14.56
King Pin dif.: +0.28
Included angle: L+14.45 R+14.21
Rear
Partial Toe: L+0.05 R+0.06
Toe: +0.11
Set back: -0.04
Camber: L-1.34 R -1.28
Camber dif.: +0.06
Thrust angle: +0.00
Front
Toe: +0.18
Set back: -0.39
Camber dif.: +0.04
Caster dif.: +0.28
Rear
Toe: +0.11
Set back: -0.04
Camber dif.: +0.06
Thrust angle: +0.00
Typical Stagea, same as mine, 0.4 degrees negative on the front and 1.3 degrees negative on the rear. Do you know if the tried using the standard camber adjusters on the rear to take some off? Or was that using their full adjustment? If that's the case, it needs adj camber bushes. Caster is good, standard they don't make much more than 3 degrees positive, 5 is so much better. No wonder the steering is improved.:D
I imagine they are adjustments using the standard camber adjusters - I haven't had adjustable camber bushes installed. These are the before and after camber settings front & back:
Front:
before: L-1.04 R-0.50
after: L-0.39 R-0.35
Rear:
before: L-1.59 R-1.58
after: L-1.34 R-1.28
They also made some fairly dramatic alterations with the Toe - the right rear before, in fact the right hand side of the car - was dropped down and evened out - the chap who served me pointed out the right rear Toe original value to me saying that I would notice an improvement in straight line smoothness - he was quite correct! :D
BUT THE STORY DOESN'T END THERE!!!
Today I had the anti-sway bars installed - now the Stagea goes around corners!!! :aroused:
I mean, it did go around corners before, just not that convincingly. Now I can feel the front wheels as the drive is transfered to the front and the car pull out of the corner/curve. I just have to get used to how the car handles now and go for a drive DURING THE DAY around some turning/twisty stuff instead of at night like I did this evening...
I would say that at the moment the Stag has more capability than I have the courage to throw at a heavy car. The car feels great and so much more enjoyable to drive - now I can imagine it doing with a little more power whereas before the car felt too powerful compared to the rolling and relatively sloppy handling that it came with from the yard.
Yeah, effen unreal!!! :)
Front:
Rear:
Yeah, effen unreal!!!  :D
Thanks for that, the standard rear camber adjusters seem to commonly remove 0.3 to 0.5 degrees of the negative. Yours and mine are both examples of that. So the camber bushes in the rear are pretty much always needed. Sometimes even two sets (both inner and outer bushes) are needed when they are lowered a fair bit.
You are so right about the stabiliser bars, they make such a difference to handling and feel of a Stagea.
The technical stuff......Being a waggon they have a lot of weight high up in the rear that is simply not there in a sedan or a coupe, that means the centre of mass is higher. Since the rear suspension is the same, the roll centre is in the same place as the sedans and coupes. This means the roll couple (distance between the roll centre and the centre of mass) is much greater and the waggons roll more for the same amount of G force (same speed and corner). That's at the rear, the front roll couple is not much different, that's why I did a big upgrade on the rear and a smaller upgrade on the front.
The non technical stuff.....I reckon upgrading the stabiliser bars is always a worthwhile mod on a Skyline sedan and coupe, doing it on a Stagea waggon is a must. The big difference I feel is when I get 2 corners close together, before it would still be recovering from the first corner when I needed to turn for the second corner. Now it is just flick flick with the steering wheel and both corners are goooooone.
Now I just need to track down my Bilsteins............
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
