I came to pick up my car from southcoast rotary today, and it was running well, but i went to do some shopping in sydney as i was waiting for some wheels, and that's when it got stolen.
It was stolen from Liverpool westfield shopping centre on the top floor today 6th January 2005 at around quarter to 4pm. The drivers passenger side window was smashed and the ignition ripped out, as i found it on the ground.
It's rego plates are ARX-73X.
It's blaze red, and still has standard steel wheels with snow tyres, has a aftermarket spoiler, and is a series 5 though the front bar looks a little different.
Here are some pictures;
http://www.cardomain.com/memberpage/749151
These are the modifications, if anyone sees any of these parts for sale, please get as much info as you can about the seller and inform me or the police.
Twin TD05-16G turbos,
Twin HKS airpods,
Twin HKS Blow off valves,
Trust external wastegate,
Knight sports bleed valve,
FD/Supra/FC fuel pump
6 Extra injectors,
Greddy rebic injector controller,
Greddy boost guage,
Blitz oil/water/boost/exhaust temps guages,
Pivot Turbo timer,
Pivot digital rev meter and shift light,
Momo wheel,
Razo shifter,
Twin bride brix adjustable seats,
5 point roll cage,
Cusco adjustable suspension/shocks,
3 inch single exhaust,
Front mount HKS intercooler,
RE-Amemiya Aero mirrors,
RE-Amemiya Rear spoiler,
Chipped ECU, ecu chipped by spec,
Also, it's quite loud and the clutch is very rough, so if you see someone bunny hopping taking off, take a closer look cause it could be this one.
I have no idea if i'll ever get it back, but if anyones interested it made 240rwhp on 9psi with 1000lbs of torque today. Pity i didn't get to feel it. :cry: :cry: :cry:
If anyone sees it don't hesitate to call me or the police, here's my numbers;
0417261902
44763566
https://www.sau.com.au/forums/topic/60513-my-car-got-stolen-today/
  • Replies 60
wtf is with the stolen cars recently!? its like the police are hiring professionals to steal high performance cars since they ain't doing shiet all about it.... how many more cars needs to be stolen til someone actually does something? and if we catch em and bash they're head in, WE GET THE FINE!
I am very sorry for your loss, but I have to ask why you parked a rather desirable modifed RX7 at westfields Liverpool to begin with, let alone with no security.
Its common knowledge that liverpool westfields carpark is a hotspot for car theft.
Regardless, I hope you recover the car in one peice
Guys give the dude a break. He probably had to do some emergency banking and get some stuff done at the shopping center.. he was probably 'on the way' to getting his car set up with security :D
Dont pay him out for his actions nobody wants to get their car stolen.
We need to set up a van with 3 SAU members with baseball bats inside. We'll get some GTR owners to pack their cars near the van on this level late one night and we'll wait for thieves.. :(
sounds like fun :)
sorry bout your car, i will keep an eye out
Clubby, kill switch, and a cable lock around the steering wheel to clutch and brake levers, no alarm [who pays attention to 'em anyway].
They'll still steal it if they really want to, but it makes it a bit harder.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
