What would be the best 2nd hand Nissan or suitable bolt-on turbo as an upgrade for a mild modded R32? eg FMIC, 3" turboback. Estimated power?
I want it to remain responsive.
What other options for $1000-$1500
I'm thinking of a late R34GTT turbo if anyone has one but I'm open to other suggestions.
https://www.sau.com.au/forums/topic/60535-budget-turbo-upgrade-for-rb20/
hybrid T3/T4e bolt on to R32 its new and is pretty responsive
$950 @turbo aust
Apparently series2 R33s and most R34s have nylon compressor and ceramic exhaust wheels but I've read the very last R34s have alloy compressor and steel exhaust wheels.
http://www.skylinesaustralia.com/forums/sh...35&page=1&pp=25 Read on from post #24 to page2
Can anyone positively confirm or refute this?
I've been told late R34 GTT turbos have a steel turbine wheel instead of ceramic and are the pick of the OEM Nissan turbos for the R32.
thats an R33 and looks like steel to me.. just grab an s1.. they're much easier & cheaper to find than R34 turbos..
Otherwise you may be able to get a 2nd hand high-flow for the price you are looking... good for well over 200rwkw..
thats an R33 and looks like steel to me.. just grab an s1.. they're much easier & cheaper to find than R34 turbos....
Only problem is the picture shown is the compressor, not the turbine. Turbine is the exhaust wheel, hence when they are ceramic they can fall off and end up in the exhaust/cat
Ive got an R33 T3 on mine, feels like this was the Turbo the RB20 was meant to have off the factory floor. Smoother, more powerful, more responsive. Cost me $350.00 for the Turbo and 2 days to install (I had to modify the oil return pipe to fit around the bigger turbo).
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
