What would be the best 2nd hand Nissan or suitable bolt-on turbo as an upgrade for a mild modded R32? eg FMIC, 3" turboback. Estimated power?
I want it to remain responsive.
What other options for $1000-$1500
I'm thinking of a late R34GTT turbo if anyone has one but I'm open to other suggestions.
https://www.sau.com.au/forums/topic/60535-budget-turbo-upgrade-for-rb20/
hybrid T3/T4e bolt on to R32 its new and is pretty responsive
$950 @turbo aust
Apparently series2 R33s and most R34s have nylon compressor and ceramic exhaust wheels but I've read the very last R34s have alloy compressor and steel exhaust wheels.
http://www.skylinesaustralia.com/forums/sh...35&page=1&pp=25 Read on from post #24 to page2
Can anyone positively confirm or refute this?
I've been told late R34 GTT turbos have a steel turbine wheel instead of ceramic and are the pick of the OEM Nissan turbos for the R32.
thats an R33 and looks like steel to me.. just grab an s1.. they're much easier & cheaper to find than R34 turbos..
Otherwise you may be able to get a 2nd hand high-flow for the price you are looking... good for well over 200rwkw..
thats an R33 and looks like steel to me.. just grab an s1.. they're much easier & cheaper to find than R34 turbos....
Only problem is the picture shown is the compressor, not the turbine. Turbine is the exhaust wheel, hence when they are ceramic they can fall off and end up in the exhaust/cat
Ive got an R33 T3 on mine, feels like this was the Turbo the RB20 was meant to have off the factory floor. Smoother, more powerful, more responsive. Cost me $350.00 for the Turbo and 2 days to install (I had to modify the oil return pipe to fit around the bigger turbo).
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
