Hey guys I have just had price given to me for a new turbo and power fc for $3,500
what do ppl think of this price the turbo is a gt 35/40 garret. The guys also said there is a much better computer to use now. So all in all what do ppl think.
https://www.sau.com.au/forums/topic/60542-new-turbo/
The GT3540 is a very nice turbo, and quite a good price. The problem I have read about is they only come with a 1.06 exhaust housing which is way too big for an RB25DET (more suitable for a rotary and RB30 and XR6T (the XR6T is a 3540 but with a smaller comp cover, .50 instead of .70 like you buy from Garrett).
You can get the turbo modified to a .82 exhaust housing which is alot more friendly and should start to make decent boost around 3500rpm. Do not go for any of the .6x sized exhaust housings as these are too violent coming onto boost and you will just wheelspin everywhere.
A guy off these forums fitted one on his RB25DET by the name of NisJet, it made 210rwkw on 12psi. His car has 3 inch exhaust, intercooler, power fc, fuel pump.
--- EDIT ---
Do a search for GT3540 and you will see a few people that have run them. Most that keep the large 1.06 housing have forged internals and need to rev the car to 8000rpm to make good power out of it. Also does that price include a new manifold? I think it was Roy on these forums a while ago wrote you need spacer plates to put it on the stock manifold or else the comp cover will hit, and it generates heat spots and warps the stock manifold.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148861
I would always stick to the big jap brands - Zoom or HPI did a review of a range of A/M turbos a while ago, and it was proven that the JAP brands kick asre over the 'copy' series that you can get.
Makes sense to get something that has been specifically developed for your application, you can get some real bargains second hand. Try http://www.tuneagent.com/index.aspx and http://www.upimports.com.au/UPI_Parts/ as for starters.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148963
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
