800 for melb buyers.. must sell now.. firm with price
Guys... got this turbo .. long story...
i need somthing bigger basically for what i wanna do with my car
heres some specs
SHAFT & WHEEL TRIM 64.5mm
TURBINE HOUSING A/R .84
COMPRESSOR HOUSING A/R RATIO .70
OIL COOLED
has t3 flange... so it bolts up to a VL manifold.. so im guessing should have no
probs with a skyline
its a 650 horse power turbo..
owes me $1250.. it came from the us.. have relos there.. as i said long story
ITS BRAND NEW
I JUST GOT IT TODAY.. LOOKED AT IT.. AND POSTED IT UP FOR SALE....
pm with offer
thanks.. danny
im in melb btw
https://www.sau.com.au/forums/topic/60570-t70-turbo-new-make-offer/
hey champ they sell these turbos new with 12 months warranty from www.toofast2furious.com for $1100. i know coz i just bought one for my skyline. Very nice turbo people good response and power. Good luck with it VLS. =-)
I'm making 287kw at the wheels on 18psi and 310kw on 22psi its a tadd bit laggy but comes on hard and you have to fight it on the road to keep traction. Thats combined with Fm IC, power fc , stainless manifold with 50mm wastegate, Avc-r and fuel upgrades. Stock internals.
not to bad..
yeh . they r decent turbos. but its not what im after..
i obviously have a VL..
flat out drag car. 2 speed. trans break.. huge cam.. motec.. huge injectors. etc etc.. i just need somthing a touch bigger im looing towards a GT42 or gt42
this turbo would make more of a street car/ take it down da track every now and then sort of thing..
any one welcome to come see this tubro.. u can eat of it its that clean.. well.. has a bit of dust and finger prints now since we had a good look at it at da work shop.. but il clean da comp cover up for ya :-)
Any chance of posting a dyno pic of this.
Thanks
nah sorry no dyno pics.. due to the fact ive had the turbo for.... 24hours now.. haha
umm ive done a bit of reasourch on em last nite.. apparently they come on boost around 3000rpm-3500rpm. best bet is to ask reidles... see if he has a dyno read out as well... from what he was saying .. it does have a touch of lag then throws u back pretty hard...
sounds like an interesting turbo on a 2.5L dohc motor
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
