running of cables in r32??
Skorj
 Share
i was just getting ready to run some cables in my 32gtr like power cable and rca's etc.. and was wondering on an easy way to get under the carpet without damaging anything?? i have done work on my old commodore where i simple took off the door foot panels and had room to run the cables there, but the 32 has no room there and when i took the panels off, the carpet seems to be stapled to the floor...
is there an easy way to run the cables that i'm not seeing??
thought i'd ask beofre i go ripping stuff out.
thanks for any suggestions..
all i did with my remote wire and rca wire was run them under then centre console under my back floor mats and under the seat the power cable i ran under the drivers side cover strip that says skyline and i gotta try n push it under the rear trims or sumthin but it goes under the rear seat aswell hope it helps
I ran two 4g power cables in my GTSt 4 door. A 2 door should be similar.
I took out the drivers side kickpanel and door foot panels.
I pulled out the front seat but maybe that wasn't necessary
The carpet is stapled to plastic clips that push onto the lip on top of the sill.
Lift these up and the carpet should fold inward. Run the power cable along the bottom of the inside of the sill, where it meets the floor. Tuck it in with the main loom. Take your time to feed it past any obstructions like boot release, seat crossmember and seatbelt etc.
If you want to run it into the boot you will need to take the back seat out and feed the cable through the small hole where the wheelarch meets the bottom of the rear 'firewall'.
I ran my RCAs and speaker cable down the passengers side in a similar manner.
Even with the thick cables and three RCAs there isn't any lumps in the carpet.
Hope this helps.
kewl kewl, thanks guys, i was just a bit worried about those staples under the foot panels, didnt want to break anything,
thanks for the help much appreciated.. might go start the job tonight..
cheers
 Share
    • It's so pretty, but I cry at the price (this setup was about $7,500 USD)
    • Yep, I installed it, the sensors, wired everything up so things like the factory blinkers work etc. Fortunately it's not a hard job, just time consuming sorting the wiring out.  If you think this dash is nice, you should check out the actually sexy dashes lol. There would be a fair few people out there that think the IC7 is ugly.  The new and sexy Haltech dash -  https://www.haltech.com/news-events/uc-10dash/ Here is a, I hate having money option from Motec -  https://precisionracing.com.au/product/motec-c1212-display/
    • @Murray_Calavera ohhh.myyyy.gawwwwd 😍 that dash is so much cleaner.  yeah I’m someone who loves older cars, but hate using old tech. A digital dash would always be the way forward. Did you install that yourself?  Thanks for the explanation on oil pressure. I’ll just take it as reference.    Also, your engine light is on 😅😅😅
    • @DraftySquash Yeah... maybe think of those gauges as a super rough estimation of oil pressure and engine temperature.  If you want to see your actual engine temp and oil pressure, you're going to need an aftermarket solution. I'll post a photo of my dash, this is a much neater solution in this day and age. I can't think of any reason why someone would start adding individual gauges.  So grab your dash, then add sensors for all the extra things you want to see.  As for what to expect from oil pressure, super quick run down = cold oil, higher pressure. hot oil, lower pressure. Low revs, lower pressure. higher revs, higher pressure. The values will change based on the viscosity of oil used, the actual temperature of the oil, the type of oil pump used, then more nuanced stuff like clearances in the engine.
    • Should run up to about 6 or so at high revs. But the stock oil pressure gauge is a piece of shit and can't be trusted, so make few to no decisions based on what you see it do.
